The ML240L performs well and should be enough for 5ghz but the included fans aren't great especially if you want a quiet cooler.
What case and ram are you using?
Where are you shopping / located?
https://linustechtips.com/topic/926238-cooler-for-8600k/#findComment-11335890
dark rock pro4 if you can get it for a good price. But since arround 70 is your limit... if you dont care about looks https://pcpartpicker.com/product/46tCmG/noctua-cpu-cooler-nhd14  if you are ok with mail in rabqtes https://pcpartpicker.com/product/kHdqqs/cooler-master-cpu-cooler-rrv8vc16prr1 or just this if you want an all in one https://pcpartpicker.com/product/F2rmP6/corsair-h60-2018-572-cfm-liquid-cpu-cooler-cw-9060036-ww
CPU: Intel - Core i7-8700K @4.9 GHz 6-Core Processor CPU Cooler: be quiet! - Dark Rock Pro 3 67.8 CFM Fluid Dynamic Bearing CPU CoolerMotherboard: MSI - Z370I GAMING PRO CARBON AC Mini ITX LGA1151 Motherboard Memory: PNY - Anarchy 16GB (2 x 8GB) DDR4 @3000 MemoryStorage: 960 evo 500gbVideo Card:place holderCase: Phanteks - Enthoo EVOLV ITX TG (Black) Mini ITX Desktop Case Power Supply:SeaSonic - EVO Edition 620W 80+ Bronze Certified Fully-Modular ATX Power Supply Case Fan: be quiet! - SilentWings 3 pwm 59.5 CFM  140mm Fan Case Fan: be quiet! - SilentWings 3 PWM High-Speed 73.3 CFM  120mm Fan Case Fan: be quiet! - SilentWings 3 PWM High-Speed 73.3 CFM  120mm Fan Monitor: Dell - S2716DG 27.0" 2560x1440 144Hz Monitor Mouse: Place holder Sony H.ear on Wireless Noise Cancelling Headphone, Charcoal Black (MDR100ABN/B)  LEOBOG K26 Wired RGB Mechanical Keyboard,Gaming Keyboard,RGB Color Backlight,104 Key,Anti-Ghosting For Full Key,Blue Switches,Aluminum Chassis,Detachable wrist rest,PC,Computer, Laptop,BLACK (Black)EZDIY-FAB Sleeved Cable - Cable extension for power supply with extra-sleeved 24 PIN 8PIN 6PIN 4+4 PIN With COMBS- Black Grey
pcpartpicker: https://pcpartpicker.com/user/resdal42/saved/sCW6XL
https://linustechtips.com/topic/926238-cooler-for-8600k/#findComment-11335904
