 I downloaded a 3rd party tool to convert my primary drive to logical drive (not C drive on which windows was installed) the tool was IM-Magic Partition resizer
When I installed and put my G drive (which is primary drive) to convert into logical drive
I apply and the errors getting started and my whole hard disk get formatted (except C drive)
I tried easeus data recovery
I care data recover
Wondershare data recover
I see my data is there but some also(i am okay if i get some too but I want)
I put recovery they ask activation keys I tried to pirate them but not happening
It doesn't happen
Can you tell me or help me to get my data
Can you tell a app which is free and can recover my data
Plz help me
https://linustechtips.com/topic/926202-need-data-recovery-help/
I've used Recuva in the past. It has a free version that can scan for lost files. To actually recover them you need the paid version though.
Let this be a reminder to read the manual and always keep backups.
I'm actually not surprised converting between partition type required a format. What did you try to do? Primary partitions are fine to use nowadays.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
https://linustechtips.com/topic/926202-need-data-recovery-help/#findComment-11335291
I brought  a new tool which is recovering files but when I click recover it says don't recover files where you lost the data. (Ex-
a .zip file is in D drive I want to recover it but I can't recover in D drive) My full hdd is formatted except C drive but I can't recover my all files in it bcz recover data is around 300gb and i have 20gb left in C drive
what would happen if i recover data in drive where my data was lost
Do I have to buy new hdd for recovery
https://linustechtips.com/topic/926202-need-data-recovery-help/#findComment-11343921
Recovering data in the drive where data was lost might overwrite lost data, and overwritten data can't be recovered by any data recovery solution. I got this information while browsing minitool's official website:), a data recovery software developer, and it should be true. So, it's better to buy a new HDD for recovery, or you can borrow an hdd for recovery, and then transfer data back to your own disk.
https://linustechtips.com/topic/926202-need-data-recovery-help/#findComment-11344205
My C drive wasn't affected in this case . I think I recover some data in C drive.
when I recover my videos in C drive and play it doesn't start
(.Mp4 extension)(vlc was installed in C drive)
my photos also not opening(if open saying no image
https://linustechtips.com/topic/926202-need-data-recovery-help/#findComment-11354154
