Need help with my computer
Go to solution Solved by TheGlenlivet,
1 minute ago, Electronics Wizardy said:
id say its overkill, you can get a i5 8400 and not notice a different in most games.
Id get a 1070 and 8400 or 2600 instead and will be better in most games.
Agreed.  If you haven't bought parts yet then balance this out a little.  Unless you have a workload that will use all the cores an 8700K has, then an 8400 and a better GPU will get you a better gaming experience.
4 minutes ago, Baltazar03 said:
Hi i am going to build a computer and i wonder if my cpu is to overkill for my grhapicscard
i have a gtx 1060 dual 6gb and a i7 8700k cpu.
when ppl buy hardware they want futureproofness too 8400 isnt that future proof,    atleast get an 8600k and if u want to play upcoming games 8700k is recommended bcoz of how poorly stuff is optimized these days
gpu can always be upgraded, cpu will not be available in a few years ( due to not sellin the same socket n what not anymore ), look what happened to haswell and ivy ( tho their fine cihps still )
2 minutes ago, TheGlenlivet said:
No, the 8400 won't overclock.  The 8600K will.  You need the K at the end and a z370 motherboard to OC.
yea but i didn't realize that i thught it was overclockable but why does it show that it can go upp to 4.0 ghz?
yea i think i will do that but i want to check a bit more.
thats turbo boost, it will clock higher when temps and power allows. This chip will sit at about 3.8 most all of the time with no configuration.
That is the turbo speed.  the max it will hit in ideal conditions.
If you want to OC, get a K CPU and a Z Motherboard.
Or Ryzen.
ok thx guys now i know.
if u even consider it, go with the 8700 u wont regret it
i went with haswell 4690k, i was happy until now i cant get a easy upgrade to a i7 anymore :P
id say, wait buying a gpu and save more money ( play on onboard for now some emulators )  or stick with the 1060 for a while, resell it when u upgrade gpu later
i where thinking off doing that and uppgrading next  cristmas becuse i don't think i will need any better graphicscard untill then
if its this christmas ( this upcoming ) i would not buy the gpu, buy a gpu when xmas arrives play emulators on 8700k onboard for a while
if its next year xmas , id get the 1060 and sell the 1060 later + buy new gpu
or just deal with the 1060 for more years :P
if u dont get the fps desired just lower some settings, to ur liking ofc :)  1060 is still afine card i still run on a 970gtx and 1060 6gb is like 10% quicker +-
7 minutes ago, Valkyrie Lenneth said:
board for a while
ok thx
