I have a galaxy s8 plus with Android Oreo and for the life of me I can't keep the srgb mode in developer options stick
I am enabling srgb,exiting dev options and re-entering and srgb mode is off
Plz help meh I dunno what todooo
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
https://linustechtips.com/topic/925850-cant-keep-srgb-mode-on/
2 hours ago, MotionFlex said:
On the S8, you want to go to Settings > Display > Screen mode and change to mode to Basic for sRGB.
Info about what each mode does:
http://www.displaymate.com/Galaxy_S8_ShootOut_01.htm
Nope it's still turning off:(
https://linustechtips.com/topic/925850-cant-keep-srgb-mode-on/#findComment-11332274
What I mean, is that's how to change to sRGB mode on the S8. You don't have to use the developer settings(Samsung probably disabled it through the developer settings because you can change it this way).
https://linustechtips.com/topic/925850-cant-keep-srgb-mode-on/#findComment-11332519
  • 2 weeks later...
oh okay thx(sry the response was late i kinda forgot about it)
https://linustechtips.com/topic/925850-cant-keep-srgb-mode-on/#findComment-11367515
  • 3 years later...
I have Micromax In Note 1. Any idea about mine?
https://linustechtips.com/topic/925850-cant-keep-srgb-mode-on/#findComment-15240081
