All Java installations fail (offline, online jre or jdk)
Solved by SHOOK_Linus,
Installed x64 version (for 32-bit computers) only limitation is RAM allowed to be used, it's set around 4GB for Java based processes Maximum, but I believe as long as you create an environment variable (google how to make this) with the name of "_JAVA_OPTIONS" and set the value to however much RAM your system has (i.e. for a 16GB RAM computer the value would be "-Xmx16000M") it should work uninterrupted. (all values are to be used without quotes)
