Help! Bend PCI Socket.
Solved by GrockleTD,
1 hour ago, hiimFred said:@AskTJ @VicciVicVic @Tabs @Grockle88
First of all thanks for the replies.
I tried to install the card on the other slots and in my surprise I couldn't. The DVI port would not play nice with the back of the case. And that's when I realized that the problem is elsewhere.
My card's back is open. That's why it bent the port.
See how it doesn't follow the straight lines.
take the cooler off and put it back on. see if the pcb un-bends.
