installing CPU(2 questions)
1 minute ago, sample text said:I bought ryzen 2700x with Wraith Prism cooler:
1.Should I use thermal paste or not?I don't know how to know if it already has applied thermal paste or not
2.Why is it so important to not touch the top of the CPU chip? Ppl always say to touch the CPU chip on the sideways
You must use thermal paste otherwise the cpu will overheat. as to tell if there is some already applied, there should be some gray paste on the bottom of the cpu cooler, if there is then your good to go. As for not touching the cpu, some things that could possibly happen is the oils from your hands could damage the cpu or static electricity. You can touch the top of the cpu where the heat sink is. Try and avoid touching the contact pins on the bottem of the cpu as that is where you could damage something
