I have been having a problem with the 3 or 4 nvidia services that run in the background keeping my CPU load above 30% at all times. They are all showing up as "NVIDIA Driver Helper Service" and I have disabled all the nvidia services to get rid of them. My system now idles at 2-3%, but this seems a little odd.
System specs:
Win 10 build 15063
i7-6700k <stock speed>
Asus  z170 pro gaming
32GB of value ram <stock speed>
Evga geforce gtx 980 ti sc <stock speed> driver version: 21.21.13.7651
I'm sure the dust in the case needs to be cleaned out (if not a whole new case at this point), but the card is dust free. Any ideas?
https://linustechtips.com/topic/925163-25-cpu-load-from-nvidia-services/
As bad as a dusty computer is, it does not increase components usage (other than the fans), unless your parts are throttling because the dust does not allow your PC parts to cool down.
Sounds like a normal idle load to me.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
