If i buy a Radeon 7770 1GB DDR5 will i be able to play assassins creed 4 or any new games? It doesn't matter if i can't play on high settings but i want to play it at a decent frames.
My current pc specs are:
Motherboard: Redfox A55F2M3
CPU: AMD A4-5300
PSU: 600W
Memory: 4GB DDR3 1333Mhz
Videocard: Radeon HD 6670 DDR3
I will be only playing at 720p because that's the highest resolution my monitor can do. Also i can only buy the radeon 7770 because there is a christmas discount. smile.gif
https://linustechtips.com/topic/92501-radeon-7770/
CPU: AMD A4-5300
PSU: 600W
If your monitor only produces 720p you should be able to play any game at 30-60 frames just fine.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/92501-radeon-7770/#findComment-1245940
The 7770 will do you well.
https://linustechtips.com/topic/92501-radeon-7770/#findComment-1245942
My old card was a 7770 I only ran into one issue with is, if you are going to get one I would advise making sure that don't strain it so much over time, eg what ended up killing mine was running skyrim with a buttload of mods
Specs
https://linustechtips.com/topic/92501-radeon-7770/#findComment-1245978
