Anyone know how to reset UEFI to default settings without entering it?
Solved by Razor Blade,
I assume that you have tried more than just one USB port when accessing your BIOS? Even 10+ year old bios will recognize a USB keyboard. Try a bare bones basic USB keyboard and nothing fancy... Even if you have to buy one for $5 from a thrift shop or something.
Also that same techinferno thread says that shorting the pads will not only not clear the CMOS, it could brick the laptop.
