I bought a cool master pro 5 rgb case n a msi z370 motherboard A-pro but on my motherboard it was missing a certain plug in to power my led light on my 3 fans so after I put the entire thing together I got my fans power but not the led lighting it was the JRGB1 those 4 needles was not there on my motherboard so how or what do I look for to see if my motherboard is compatible with my cool master case
https://linustechtips.com/topic/924393-i-need-help/
Your motherboard does not have an RGB header, so you need to buy an RGB controller seperately. Make sure the controller connects to a USB 2.0 port, as your motherboard has 2, marked as 'JUSB1~2'
Desktop benching:
https://linustechtips.com/topic/924393-i-need-help/#findComment-11317444
yes in that bottom left corner the 4 needles that suppose to be there is not on my mother board so idk if that was a mistake or if there's another place on the MB to install my 3 to 1 cable thing or is there also another plug coming out of my case to go into my MB
https://linustechtips.com/topic/924393-i-need-help/#findComment-11318202
1 minute ago, KAMUELA_O_KEKOA said:
there this is the bottom left corner of my MB is that wrong or is it suppose to be like that
It's normal. That RGB header would be functional in a higher end model. The thing is, you bought the cheaper model, so MSI chopped that feature off so people who wants RGB would spend more for it.
Desktop benching:
https://linustechtips.com/topic/924393-i-need-help/#findComment-11318280
