hey all, i have a asus z370-a prime mbd and i was looking to overclock my new i5 8600k, i'm not sure if my mbd comes with auto overclocking software or if anyone can give me a good oc for my cpu i can manually put in, i have a dark rock pro 3 so i reckon i could get to 5ghz but if i pushed it that far would it damage it or what exactly would happen?
Cheers All
https://linustechtips.com/topic/924389-how-to-overclock-a-cpu/
Do some research and watch some youtube tutorials. Doing anything related to overclocking has a significant chance of killing your cpu if you have no idea what you are doing. Understand the concepts of heat, voltage, frequency, and current (strangely this one is often left out).
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/924389-how-to-overclock-a-cpu/#findComment-11317400
Unless you have a high end graphics card or a SLI/cross config there's no need to overclock that CPU right now.
If it performs good don't touch it, think about OC when the CPU starts bottlenecking the graphics card or if you use certain programs that benefit from the raw IPC increase that comes with ocing
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/924389-how-to-overclock-a-cpu/#findComment-11317406
Try taking some baby steps first before trying to go straight from 3.6Ghz to 5Ghz.
Most modern Asus motherboards come with auto overclocking built in to the BIOS. Switch your BIOS in to simple mode and it will likely have an option for a couple of different CPU settings such as "Eco, Normal, Extreme" or something similar.
I'd recommend going in to the BIOS and making small, basic changes to achieve an overclock. Slightly increase the base clock multiplier to get a few hundred extra MHz. Try going from 3.6Ghz base frequency to 4GHz. Then you can get familiar with the other processes involved in overclocking such as stress tests, running benchmarks and monitoring thermals. When you're comfortable with the overclock you have, you can go back in to the BIOS and try and increase it slightly again. This time go for 4.1GHz and do the benchmarks and stress tests. Keep repeating this process, going slightly higher each time. Eventually you will hit a point where your overclock will become unstable at its default voltages and stress tests will start to fail, you'll see BSODs, or even just complete shut downs. When you start running in to these problems you can look in to more advanced overclocking with adjusting voltages and the like.
https://linustechtips.com/topic/924389-how-to-overclock-a-cpu/#findComment-11317418
same principle. Its easy.
CPU: Ryzen 7 5800x3D | MoBo: MSI MAG B550 Tomahawk | RAM: G.Skill F4-3600C15D-16GTZ @3800CL16 | GPU: RTX 2080Ti | PSU: Corsair HX1200 |
Case: Lian Li 011D XL | Storage: Samsung 970 EVO M.2 NVMe 500GB, Crucial MX500 500GB | Soundcard: Soundblaster ZXR | Mouse: Razer Viper Mini | Keyboard: Razer Huntsman TE Monitor: DELL AW2521H @360Hz |
https://linustechtips.com/topic/924389-how-to-overclock-a-cpu/#findComment-11317700
