So I updated my rig and now when I plug in my headset Hyperx Cloud II it works and everything is fine, but I can't hear any1 ingame in OW and they can't hear me if I talk.. The next thing is that my mic also doesn't work in discord, but it works when I go in recordings and press to listen to the device.. Did I disable something while disabling most of the unecessary stuff for windows10 which caused it? I can only hear myself here > when I check listen to this device and press apply.. only there I can hear myself and when I'm talking it doesn't pickup my voice in recordings? I think it should right? image.thumb.png.af2783908eb0aa096ec7babdd9ac60f5.png
PC Specs
CPU i7 8700k
GPU ASUS GTX1070 DUAL O8G
MOBO ASUS Z370 ROG STRIX GAMING-F
RAM G.SKILL RIPJAWS V 8GB 3200MHz  CL14
CPU Cooler Cryorig H5 Universal
PSU Corsair HX750i
SSD SAMSUNG 960EVO 250GB
HDD Western Digital Blue 1TB 7200RPM 64MB cache
https://linustechtips.com/topic/923752-mic-doesnt-work-please-help/
Do you have the the hedset set as the default input device?
Is your headset set as the input device in discord?
Quote or tag me @Lemtea so I can see your reply.
DAYBREAK: R5 5700X3D | RX 9070XT | 32GB RAM | 1TB 970 EVO PLUSCRUCIAL MX200 1TB SSD | 4TB HDD | CORSAIR TX650M | PURE BASE 500DX | WIN 10
LAPTOP: DELL XPS 15 9570 i7 8750H | GTX 1050TI MAX Q | 16GB RAM | 500GB PCIE SSD | 4K TOUCHSCREEN Win 10 PRO
