CHKDSK finding problems that don't exist?
Go to solution Solved by CookieMaster,
Might be windows being stupid, windows problem.
Edit: Must be a glitch since the new update just came out as well
So I was running a CHKDSK scan on my computer to see if there were possibly any issues with my drives. After running it, it said Windows found problems so run CHKDSK /scan to fix the problems found. Well, I ran CHKDSK /scan and it said that it found no problems. But if I run the first CHKDSK command again it says the same thing about Windows found problems.
Any idea on what's going on here? Seems like I've been having these issues since the Windows 10 April 2018 update.
https://linustechtips.com/topic/923336-chkdsk-finding-problems-that-dont-exist/
