i just did my loop and started filling it up. the plugs from my res wasnt wasnt screwed all the way in. i emptied the loop and screw as much as i could in. now i filled the loop and its running fine. the there is still dripping water out of the plugs. i dont know what to do as i screwed the in as much as i could
i spent $3500(23,000dkr.) on building my pc and i only play csgo on low settings..
:Specs:
CPU: Intel Core i7-6700  CPU: Cooler: H100i v2  GPU: Gigabyte GTX 1080 G1 Gaming  RAM: Corsair Dominator 3000mhz 16GB  SSD: Kingston 960 GB  Motherboard: ASUS ROG Maximus viii Formula  PSU: Corsair RM 750x 80+ Gold  CASE: Coolermaster H500P
https://linustechtips.com/topic/923123-need-help/
you probably need new plugs. either you broke them some how, or they are just faulty. either way, definitely don't run your pc until you replace these.
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
https://linustechtips.com/topic/923123-need-help/#findComment-11305498
Are you using the recessed ports? are you using the proper port extenders?
https://linustechtips.com/topic/923123-need-help/#findComment-11305500
i fixed it. something wrong with the plug as i could not get it all the way in. god a other plug and worked fine
:Specs:
https://linustechtips.com/topic/923123-need-help/#findComment-11305928
