I need a computer for light video editing and heavy gaming I want it to be able to play any game on at least 1080p. I don't have a 4k or 1440p monitor yet but I might get one. Is it possible to build a 1440p computer for less than 1000$. Would love a list or suggestion.I am looking for very smooth frame rates. I already have the peripherals. I don't want to have to replace it any time soon
https://linustechtips.com/topic/922172-help-1000-build/
34 minutes ago, SWORDFIN said:
Also is buying parts of ebay a good idea. I really need this things to be cheap.
are you looking to get things second hand? used parts will give you the perf/$ only when you buy a bit older stuff... current stuff on ebay isn't any cheaper than retailers. actually with retailers giving you free shipping and other price deals it's just plainly more expensive.
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/922172-help-1000-build/#findComment-11296219
I would go with something like this:
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($174.79 @ SuperBiiz)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard  ($73.88 @ OutletPC)
Memory: Team - T-Force Delta RGB 16GB (2 x 8GB) DDR4-3000 Memory  ($159.99 @ Newegg)
Storage: Inland - Professional 120GB 2.5" Solid State Drive  ($32.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($43.85 @ OutletPC)
Video Card: EVGA - GeForce GTX 1070 Ti 8GB SC GAMING ACX 3.0 Black Edition Video Card  ($509.99 @ Amazon)
Case: Deepcool - DUKASE V2 ATX Mid Tower Case  ($39.99 @ SuperBiiz)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($26.99 @ Newegg)
Total: $1062.47
Generated by PCPartPicker 2018-04-30 12:52 EDT-0400
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/922172-help-1000-build/#findComment-11296224
Build something like this.....
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($178.99 @ Amazon)
Motherboard: ASRock - B360M Pro4 Micro ATX LGA1151 Motherboard  ($87.31 @ Newegg)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  ($69.99 @ Adorama)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.79 @ OutletPC)
Case: Cooler Master - MasterBox Q300L MicroATX Mini Tower Case  ($38.99 @ SuperBiiz)
Power Supply: SeaSonic - FOCUS Plus Gold 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($54.99 @ Newegg)
Total: $1160.04
Generated by PCPartPicker 2018-04-30 14:41 EDT-0400
It is over budget by $160..
It has more reliable parts than above mentioned build....also... it'll provide better fps in games.....
If u wanna save a little....get an old used 980ti fr about $300... ND u can save a few bucks....
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/922172-help-1000-build/#findComment-11296593
which program are you gonna use for video editing? monitor included in the budget?
https://linustechtips.com/topic/922172-help-1000-build/#findComment-11297743
