...using this website
https://www.digitec.ch/en/s1/tag/pc-components-76
Build the best 1080p gaming rig you can build with less than 1000.- (prices are in Swiss Francs)
Monitor and peripheals not needed.
The website is really good, has all the most common components and powerful filtering and sorting systems to find anything you need.
You can put item on card or wishlist and then do a print screen at the end.
https://linustechtips.com/topic/921770-help-me-to-build/
Thanks for the input.
This was my first attempt
https://www.digitec.ch/en/ShopList/Show?shopListId=19729A929C923594369C9B514319DE89
-M.2 SATA SSD for the same price (one cable less)
-I know PSU is a bit overpowered but I prefer for future expansion
-Maybe I can also downgrade to only 1TB HDD to save some money.
Of course CPU and GPU is the big discussion I guess.
I also went for the 1060 at the beginning but I find it quite expensive. Will the 4GB 1050 Ti be a good compromise?
For the CPU I am a bit clueless, I was tempted to take the i3 8100.. That i5 has 6 cores but I am skeptical on the clock speed of "only" 2.8GHz (must say that it has 4GHz turbo boost tho..)
https://linustechtips.com/topic/921770-help-me-to-build/#findComment-11292171
