Input lag
Go to solution Solved by XDXD_4U3IF1P,
10 hours ago, AayushSharma64 said:
So is 4.5ms input lag good
Thats fantastic input lag based on what I have read. Anything under 10ms is very good.
I was thinking of buying dell gaming s2716 dgr. Its 144 hz, qhd, 1 ms response time and 4.5 ms input lag. I am not an expert on monitors. So is 4.5ms input lag good for BR games (pubg mostly and a little bit of fortnite). If not, any other g sync monitors under 500 usd that are better than this?
https://linustechtips.com/topic/921513-input-lag/
That's pretty good afaik
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
https://linustechtips.com/topic/921513-input-lag/#findComment-11289395
CPU Intel i7 8700K @5Ghz Motherboard ROG Maximus Hero 10 RAM Corsair Vengeance 32GB 3600MHz
GPU MSI Gaming X 1080ti Case Thermaltake Core P3  Storage SSD Boot plus Samsung 960 Evo M.2 nvme storage
PSU Corsair RM750W Gold Display Asus ROG Strix XG32VQ 144Hz 1440p Cooling Corsair H100i V2
Keyboard Roccat Ryos MK FX Mouse Roccat Kone Aimo Audio MK3 Fostex T50RP + Schiit Magni 3 AMP and Modi 2 DAC
Operating System Win 10
VR HTC Vive, Audio Strap Motion Platform DOF Reality 2 DOF
https://linustechtips.com/topic/921513-input-lag/#findComment-11290977
