Enthoo Pro M
Go to solution Solved by Msuni,
1 minute ago, LoGiCalDrm said:
Yes. And as you are probably new to desktop PCs, you can easily check this by looking at both specs. Motherboard is ATX. Case supports everything from E-ATX to smaller.
Yes i am new. Thanks for the info :)
Yes
Desktop benching:
https://linustechtips.com/topic/921506-enthoo-pro-m/#findComment-11289368
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/921506-enthoo-pro-m/#findComment-11289374
1 minute ago, October22nd said:
Ok good, the motherboard arrived today so was just double checking. :) thanks
usually it's not the motherboard that doesnt fit, but the graphics card or CPU cooler.
Desktop benching:
https://linustechtips.com/topic/921506-enthoo-pro-m/#findComment-11289376
