So I was helping my brother fix his car, fitting a new radiator.
I noticed they were really quite similar to a PC radiator and thought "Hey, could this be used for a PC?"
Given how cheap they can be at a breakers yard (the same price as a regular pc radiator), I wonder if anyone had tried it before.
Ignoring the obvious impracticalities of having such a large radiator, Is this something feasible? would it perform any good?
Has anyone done this before?
https://linustechtips.com/topic/921491-engine-radiator-cpu-cooling/
well, car radiators are often aluminium, making them unusable in a loop without going for all aluminium components to prevent corrosion.
also, car rads are really not that refined when compared to PC rads. they often have some debris in there from manufacturing, and especially when you get one from a wreckers yard you are going to have a hell of a time cleaning it out before it can be used with parts like a waterblock wich microfins.
While this would be cool it would be better to get something purpose built for the job.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
Just now, GMWolf said:
yes of course. I'm not considering doing it.
Just for fun, you know?
Would it be fun? yes
Is it worth your time doing it? no
زندگی از چراغ
If you search for a car rad you can even find one made of copper. But it is pointless. You can even use a very high fin density rad for the car airconditioning unit.
CPU: i7 8700K OC 5.0 gHz, Motherboard: Asus Maximus VIII Hero (Z170), RAM: 32gb Corsair Vengeance RGB 3200 mHz, GPU: Asus Strix OC gtx 1080ti, Storage: Samsung 950pro 500gb, samsung 860evo 500gb, 2x2Tb + 6Tb HDD,Case: Lian Li PC O11 dynamic, Cooling: Very custom loop.
CPU: i7 8700K, Motherboard Asus z390i, RAM:32gb g.skill RGB 3200, GPU: EVGA Gtx 1080ti SC Black, Storage: samsung 960evo 500gb, samsung 860evo 1tb (M.2) Case: lian li q37. Cooling: on the way to get watercooled (EKWB, HWlabs, Noctua, Barrow)
CPU: i7 9400F, Motherboard: Z170i pro gaming, RAM: 16gb Corsair Vengeance RGB 3200 mHz, GPU: Sapphire Vega56 pulse with Bykski waterblock, Storage: wd blue 500gb (windows) Samsung 860evo 500Gb (MacOS), PSU Corsair sf600 Case: Motif Monument aluminium replica, Cooling: Custom water cooling loop
Oh, that's right, the aircon rad may be more suitable. though not as big.
