Best IMO is the Corsair ML120 Pro White LEDs. I have 3 120s and 3 140mm versions in my PC and love em. I feel they are a good value for their performance.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/921005-white-led-fans/#findComment-11284780
I love thermaltakes riing fans. Not too expensive if you get a single color instead of rgb, they move quite a bit of air and are surprisingly quiet.
Also, the best leds of any fans. I think the ones that just shine a bunch of leds right on the blades look too tacky and cheap tbh. These more of accent a build than light up the interior
Fanboys are the worst thing to happen to the tech community World. Chief among them are Apple fanboys.
https://linustechtips.com/topic/921005-white-led-fans/#findComment-11284801
Where are you shopping/located? Budget?
What are your specs and where are you planning to use the fans?
https://linustechtips.com/topic/921005-white-led-fans/#findComment-11287818
