Best aio cooler
I feel free to give you my thoughts on this, take it with a grain of salt. I dont want to trigger anyone but here is my experience with AiO's.
They are all pretty similar, how they are build, how much they cool, how loud they are. The only changing factors are Radiator size and Fans.
-most AiOs are using the same pump on different revisions without any real improvements in cooling performance or noise. (thx to aseteks patent rights)
-every AiO will get louder after some time and lose cooling performance, its always air trapped inside every AiO, which mostly cant be changed due to its sealing.
they are industrial manufactured this way. Impossible to change if you want it to be sealed and maintenance free. You can shake it like you want maybe you get the air out of your pump for quite some time but it will repeat over and over again because the air cant get out anywhere.
-none of them comes with really decent fans or IF it is as expansive as other AiO's including buying the fans of your choice seperate.
-every AiO with software has bad software.
Imho the best choice you can make is buying one of those expandable units. One way would be to buy a Alphacool Eisbaer variant and mod it. Clean it, change the hoses and fittings for higher flowrate, change the fans to something like Noctua Black.swap Chromax fans and bleed it with your own coolant, maybe even add a small reservoir to avoid air getting into the pump, it has a relatively weak pump compaired to Aseteks variant, but you can also change that if you are "unpleased". Only downsite would be a small maintenance once in a year (refilling) and a little bigger every second year (cleaning). But well you atleast get a real copper radiator..
Example Video:
Make sure to turn on subtitles (its in german)
