Hi, im new on here and I have a couple questions First, I have the h100i cpu cooler, I want to change out the stock fans for some rgb ones. I bought several 120mm fans and they don’t fit. Am I buying the wrong size? Would these fans work:
upHere 3-Pack Wireless RGB LED 120mm Case Fan,Quiet Edition High Airflow Adjustable Color LED Case Fan for PC Cases, CPU Coolers,Radiators system
https://linustechtips.com/topic/920751-fan-compatiblity/
Any standard 120mm fan will work.
How are the fans not fitting? The sizing is standardised, so either you have a 280mm cooler (takes 140mm fans), or the fans are 140mm while the rad is 240mm, depending on whether the fans are too big or too small. If the fans are 120mm and the rad is 240mm, they should fit just fine.
https://linustechtips.com/topic/920751-fan-compatiblity/#findComment-11282409
In what way don't they fit? They should as the H100 is a dual 120mm setup :S
DAEDALUS (2018 Refit) - Processor: AMD Ryzen 5 - 1600 @ 3.7Ghz // Cooler: Cooler Master Hyper 212 LED Turbo Black Edition // Motherboard: Asus RoG Strix B350-F Gaming // Graphics Card: Gigabyte GTX 1060 Windforce 6GB GDDR5 // Memory: 2 x 8GB DDR4 Corsair LPX Vengeance 3000Mhz // Storage: WD Green - 250GB M.2 SATA SSD (Boot Drive and Programs), SanDisk Ultra II 120GB (GTA V), WD Elements 1TB External Drive (Steam Library) // Power Supply: Cooler Master Silent Pro 700W // Case: BeQuiet Silentbase 600 with SilentWings Mk.2 Internal Fans // Peripherals: VicTop Mechanical Gaming Keyboard & VicTsing 7200 DPI Wired Gaming Mouse
PROMETHEUS (2018 Refit) - Processor: Intel Core i5-3470 @ 3.2Ghz // Cooler: Cooler Master 212 EVO // Motherboard: Foxconn 2ABF // Graphics Card: ATI Radeon HD 5450 (For Diagnostic Testing Only) // Memory: 2 x 4GB DDR3 Mushkin Memory // Storage: 10TB of Various Storage Drives // Power Supply: Corsair 600W // Case: Bitfenix Nova Midi Tower - Black
SpeedTest Results - Having Trouble Finding a Decent PSU? - Check the PSU Tier List!
https://linustechtips.com/topic/920751-fan-compatiblity/#findComment-11282413
3 minutes ago, John1212 said:
They don’t line up with the holes in the radiator.
they might be 140mm I’m not sure though.
Do you have a product page that you bought the fans from? Or post a picture of the fan next to the radiator or something.
https://linustechtips.com/topic/920751-fan-compatiblity/#findComment-11282549
I’m at school right now I’ll post some pics when I get home to sow how they don’t fit and I’ll take some measurements of the radiator,the stock fans, and the ones I bought. Here’s a pic I have just laying around on my phone the blue rgb fans are the ones that don’t fit they’re to small and they’re 120mm
https://linustechtips.com/topic/920751-fan-compatiblity/#findComment-11282579
Quote
@John1212
That's not a H100i. It's a 280mm cooler (H110i or H115i) that takes 140mm fans.
https://linustechtips.com/topic/920751-fan-compatiblity/#findComment-11282612
yeah. just compared those to the size of the fans in the rest of the case... definitely not the same
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
https://linustechtips.com/topic/920751-fan-compatiblity/#findComment-11282617
