PS4 Controller not being recognised
Go to solution Solved by chckovsky,
15 minutes ago, P-Body said:
As the website stated it's a charging cable. It's not unlikely that the cable won't carry data.
So unless you have bluetooth connectivity on your computer, a new cable is required. BUT -  the micro USB cable is extremely common. I find it hard to believe you don't have a spare one in your home.
Hi,
i had bought a cheap cable for my ps4 controller off eBay which had stopped working and i have just ordered a new one which has just arrived. I use it mainly for Rocket league which automatically detects  usually if a controller is connected but for some reason its not being recognised it is not the controller as it still works. However the cable i have ordered for some reason it has to mini usb connectors at the end which i think is to be used for two ps4 controllers can it not be used with one? http://www.argos.co.uk/product/5652848
Do i need to order a different cable again?
https://linustechtips.com/topic/920717-ps4-controller-not-being-recognised/
Main rig: i7 8086K // EVGA Z370 Micro // 16GB Gskill TridentZ 3200Mhz CL14 // Sapphire Pulse RX 7800XT// a variety of noctua cooling // Corsair RM750x v2 //  Fractal Meshify C
Secondary rig: R5 3600 // MSI B450i Gaming Plus // 16GB Gskill FlareX 3200CL14 // MSI GTX 1080ti Gaming X // Cooler Master V650 // Fractal Meshify C
Audio setup: Audient iD4 // Adam A7X // Sennheiser HD 650 // Sennheiser HD 25-II // Audio Technica M50x // Sennheiser Momentum 4
