I've done a lot of thinking and have decided on getting a non gaming oriented laptop due to me already having gaming desktops at home. I've been looking for a laptop that's not very thick, has an absurdly long battery life, and has a nice keyboard to type on. From what I've gathered everyone is recommending a thinkpad. I've taken a liking to the t470 with features such as thunderbolt 3 port, Longest battery life of any modern laptop (correct me if im wrong), one of the best typing experiences, thin enough to not burden me, nice look (as to not gather attention. Unimportant but appreciated), Future up-gradable, built like a tank, and powerful enough to do all my studies and future programming. I'll be spending north of 1000 USD on the device brand new. I know that there are used one's for a lot less but I do feel comfortable buying a new device as to not dealing with any sort of wear from previous users or future problems.
Here is my biggest issue.  Will I be able to use the same charging adapter for the t470 if go to europe? Any help is appreciated!
https://linustechtips.com/topic/920689-programming-laptop-help/
If its bought in the US there is probaby a US plug with it.
Here is the different region power plug types:
Billedresultat for eu plug
Please mention or quote me if you want a response. :)
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
https://linustechtips.com/topic/920689-programming-laptop-help/#findComment-11281929
Get the newer model: T480. Much better CPU (and optional MX150 GPU too)
Back to topic, you probably need an adapter for that
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/920689-programming-laptop-help/#findComment-11281931
https://www3.lenovo.com/us/en/p/20L5CTO1WWENUS0/customize?guid=a482bf6e-bea9-4b31-a972-2cfa5cb593ad&options_11=&options_19=5PS0A14085&options_45=5PS0K82830   how's this?
https://linustechtips.com/topic/920689-programming-laptop-help/#findComment-11281954
Just now, spiralfuzion said:
I don't think i need to upgrade cpu for programming and web browsing do I?
https://linustechtips.com/topic/920689-programming-laptop-help/#findComment-11281955
2 minutes ago, spiralfuzion said:
Looks good. Just need to add SSD. Also, I suggest you to get single 8GB RAM for future upgrade even though you get extra performance from dual channel memory.
Desktop specs:
https://linustechtips.com/topic/920689-programming-laptop-help/#findComment-11281960
darn i thought i changed to single stick will do. IDK if ssd is worth it atm. I know the speed is worth it but I  can always open it and add it in the future can't I?
https://linustechtips.com/topic/920689-programming-laptop-help/#findComment-11281965
Yes, Thinkpad T series are designed for easy upgradability. However I strongly suggest you get a SSD ASAP, W10 will run much smoother
Desktop specs:
https://linustechtips.com/topic/920689-programming-laptop-help/#findComment-11281975
If you can get a T470 with an SSD for $1000 you certainly won't be disappointed. I have an L480 which is slightly thicker, but it's also a bit cheaper so if you are looking to get 16GB of RAM (like I wanted) for instance, than it won't break the bank.
And you should really look into the adapters more closely than just the plug, we do have different voltages over here so I am assuming you will need a different adapter or a converter. Safest bet is to just chat with the people over at Lenovo themselves. Maybe they already have something for that and you can get it at a discount when ordering the laptop.
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
https://linustechtips.com/topic/920689-programming-laptop-help/#findComment-11281994
4 minutes ago, martward said:
L480
Worse build material and less features (keyboard not that water resistant, no swappable battery) compared to T series. Don't get me wrong, it's still a great laptop.
10 minutes ago, Ashh_x3 said:
G50-G80 Lenovo laptop
Eh, that model is pretty mediocre. Especially build quality and battery life.
Desktop specs:
https://linustechtips.com/topic/920689-programming-laptop-help/#findComment-11282006
Dude if you have it you know the pain.. I cant play roblox on it wothout bugging ! So thats why i have a desktop gaming pc --..--
https://linustechtips.com/topic/920689-programming-laptop-help/#findComment-11282007
The laptop isn't designed for that purpose, I'm pretty sure you know it
Desktop specs:
https://linustechtips.com/topic/920689-programming-laptop-help/#findComment-11282010
well i think opting for a t480 is better due to the newer cpu. But is 128GB really enough? should i just get a portable hard drive for 50 bucks?
https://linustechtips.com/topic/920689-programming-laptop-help/#findComment-11282012
I have a special backpack for all my tech. I'll be traveling so I can just keep it with me. instead of opting for a 200 dollar 256GB ssd.
Yes! That is smart,but why dont you just buy a 500gb hd for the laptop and put it in..Its easy.
https://linustechtips.com/topic/920689-programming-laptop-help/#findComment-11282021
And it is expensive..
But your money dude.. I dont want to tell you how to spend your money..
well it's not that much more expensive than the 500GB HDD. but yeah I could just buy a ssd and throw it in there haha.
https://linustechtips.com/topic/920689-programming-laptop-help/#findComment-11282028
For OS, sure
Desktop specs:
https://linustechtips.com/topic/920689-programming-laptop-help/#findComment-11282034
4 hours ago, Ashh_x3 said:
True, though the L480 has the MIL-SPEC stuff. It is worse in those cases, but since it is cheaper that means you can get better hardware inside (I really really wanted 16GB of RAM for relatively little money).
Depends, if you plan on dual booting Linux and Windows it's very tight. 256 would be better if possible, is the difference in price really that big?
My System:
https://linustechtips.com/topic/920689-programming-laptop-help/#findComment-11282802
