16 minutes ago, Angel1231 said:
What do you need your PC for, and what's your monitor resolution/refresh rate?
https://linustechtips.com/topic/920429-will-it-work-well/#findComment-11279380
Well it are top of the line components, so no problem in that regard, but pairing such a beast with 1080p 60Hz is a bit of a waste in my opinion.
Also I'm not sure if you can do surround with 3 displays (if that's what you're after) on that single card, since it has only 2 DP outputs (not sure if you can mix DP and DVI), but maybe you're just after multitasking.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
https://linustechtips.com/topic/920429-will-it-work-well/#findComment-11279448
18 minutes ago, Angel1231 said:
gaming i am using 3 BenQ Gw2760
I'm just going to suggest you get a way more reasonable PC that's still pretty good.
Saving the rest of the budget for a next generation GPU in a few months, rather than overpaying for a 1080ti.
In any event get a case that actually has airflow, but I guess if you want overkill...w/e
PCPartPicker part list: https://ca.pcpartpicker.com/list/7x8rr6
Price breakdown by merchant: https://ca.pcpartpicker.com/list/7x8rr6/by_merchant/
CPU: AMD - Ryzen 5 2600X 3.6GHz 6-Core Processor  ($286.75 @ Vuugo)
CPU Cooler: Cooler Master - MasterLiquid ML240L RGB 66.7 CFM Liquid CPU Cooler  ($77.99 @ Newegg Canada)
Motherboard: Gigabyte - X470 AORUS ULTRA GAMING ATX AM4 Motherboard  ($175.99 @ PC-Canada)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($215.99 @ Newegg Canada)
Storage: Western Digital - Blue 500GB M.2-2280 Solid State Drive  ($153.92 @ Mike's Computer Shop)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($68.99 @ Amazon Canada)
Video Card: EVGA - GeForce GTX 1070 Ti 8GB SC GAMING ACX 3.0 Black Edition Video Card  ($699.99 @ Memory Express)
Case: Cooler Master - MasterCase H500P Mesh White ATX Mid Tower Case  ($189.99 @ Amazon Canada)
Power Supply: SeaSonic - FOCUS Plus Gold 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($150.99 @ PC-Canada)
Total: $2020.60
Generated by PCPartPicker 2018-04-25 12:59 EDT-0400
https://linustechtips.com/topic/920429-will-it-work-well/#findComment-11279451
41 minutes ago, Angel1231 said:
thank you for your input it was helpfull xD
As a side if you do go Ryzen probably get the R7 2700X just to have 8 cores
https://linustechtips.com/topic/920429-will-it-work-well/#findComment-11280223
