Define C Fan Mounting
Go to solution Solved by LienusLateTips,
It's 2 120mm/1 140mm, if you have no HDDs and remove part of the PSU shroud, and doing that gives you an extra 1 120mm/140mm I believe from looking at mine
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/920389-define-c-fan-mounting/#findComment-11278983
