Ok, I hope people don't mind me posting this here as I wasn't sure where else to post this.
I'm in need of a surge protector with roughly 10-12 plugins and I know absolutely nada about surge protectors and UPS.
I'd probably prefer to have 2 rows of plugins facing outward on opposite sides as I'll likely have 3-4 3.5" externals plugged in along with my desktop PC, Phillips Hue hub, Modem/Router combo, a light and whatever else I'll need to plug in.
I'm not sure if I need a UPS. I'd prefer to spend only $50-$100 CAD. Typically the power doesn't cut out randomly where I live, usually only if there's extreme weather such as a snowfall or someone in the house decides to use too much power in one general area and a breaker pops. Having said that, I have had my desktop shut off 5x in one day before, but that's extremely rare. I can usually go a full year with the power cutting out maybe once or twice. So I don't know if I should consider a UPS.
What do you guys recommend? Looking to buy asap. If you don't know what I should buy but have some general tips to steer me in the right direction, I'm fine with that as well.
https://linustechtips.com/topic/920268-surge-protectorups/
A decent quality surge protector would be the bare minimum. Good brand such as GE, APC, Philphs, Tripplite, Bellini Belkin and such would be ones to look for.
My usual go to recommendation would be this one from APC.
https://www.amazon.com/APC-Protection-SurgeArrest-Performance-P11VT3/dp/B0012YLTR6/ref=mp_s_a_1_4?ie=UTF8&qid=1524630116&sr=8-4&pi=AC_SX236_SY340_QL65&keywords=apc+surge&dpPl=1&dpID=41X9mAHskyL&ref=plSrch
Edited by W-L
https://linustechtips.com/topic/920268-surge-protectorups/#findComment-11277889
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/920268-surge-protectorups/#findComment-11277911
1 minute ago, IgorM said:
Any recommendations of an affordable UPS that is capable of delivering DC energy to power a router and usb devices?
Most UPS units are AC based you can get mini DC based UPS units but they aren’t as common.
Pico UPS allows you to make a custom sized DC to DC UPS.
http://www.mini-box.com/picoUPS-100-12V-DC-micro-UPS-system-battery-backup-system
https://linustechtips.com/topic/920268-surge-protectorups/#findComment-11277936
7 minutes ago, W-L said:
A decent quality surge protector would be the bare minimum. Good brand such as GE, APC, Philphs, Tripplite, Bellini and such would be ones to look for.
Looks pretty ancient. People still use Coax, DSL and wired telephone lines? Why's that your "usual" recommendation?
See photo: I actually use an older surge protector for my TV that I tried to use with my computer gear today because it has more plugins..... BUT I think It's only intended to be used with TV gear such as VCRs/DVD/CD players etc., hence the labeling. I'm not sure if it makes a difference? When I plugged my computer gear into this surge protector, my computer would boot, but my monitor would enter "low power saving mode" even when I tried two different plugins for my monitor and I also tried plugging it into my original surge protector with no luck.
So I shut my computer down and I'm back to using the other surge protector with less plugins and everything is fine. I'm not going to trust that other surge protector with externals and my computer gear if it can't power on a monitor lol.
https://linustechtips.com/topic/920268-surge-protectorups/#findComment-11277943
That’s what makes it good since you have all possible options for surge protection if needed.
The labeling doesn’t matter it makes no difference at all.
For a regular UPS what’s your system specs and devices you plan to power.
https://linustechtips.com/topic/920268-surge-protectorups/#findComment-11278746
If you are gonna wire up a router, don’t see why you wouldn’t want the coaxial cable in there too.
Gonna need an power strip to wire up 12 things for that.
Normaly some outlets do protections while the others do backup and protection. Both have a power limitation.
I only use mine for my main pc, the main monitor, router and modem. Works like a charm.
https://linustechtips.com/topic/920268-surge-protectorups/#findComment-11279225
Hmm, then why does the surge protector in my photo not play nice with my computer? The other surge protector I'm using works and It's just some cheapo $10 surge protector that you can find any where.
Computer:
-Motherboard: Gigabyte Z87X-D3H
-Processor: Intel Cord i7-4770 CPU @ 3.40GHz
-RAM: Kingston 16 GB DDR3
-GPU: EVGA GeForce GTX 770 Superclocked w/ EVGA ACX Cooler
-PSU: Seasonic MI2 Bronze Evo Edition. 750W ATX 12V
-Intel Internal 250 GB SSD
-2 TB Internal Seagate HDD
-1 TB Internal HDD
Devices Plugged In:
-3 or more External HDDs 3TB+
-Philips Hue Hub
-Modem/Router Combo
-24" Dell Monitor
-A light
https://linustechtips.com/topic/920268-surge-protectorups/#findComment-11285495
It's a modem/router combo that my ISP (Telus) supplied to me. It plugs into the surge protector and that's it. I don't know what I'd use a coax cable for in this situation? I'm not even sure why coax exists.
In the past I used routers, but there's really no need because my ISP doesn't charge me for the modem/router and I get what I'm paying for 150 up/down. Routers use coax?
https://linustechtips.com/topic/920268-surge-protectorups/#findComment-11285498
Well there has to be some connection from the line to my house. In this county, that’s coaxial.
https://linustechtips.com/topic/920268-surge-protectorups/#findComment-11286066
On 4/27/2018 at 2:39 AM, Vectraat said:
-SNIP-
Any surge protector will do it's job no problem as for a UPS your system won't draw over 500W so something like this will provide enough overhead including peripherals and networking equipment.
https://www.cyberpowersystems.com/product/ups/cp1350pfclcd/
http://www.apc.com/shop/us/en/products/Back-UPS-PRO-BR-1350VA-SineWave-10-Outlets-2-USB-Charging-Ports-AVR-LCD-interface/P-BR1350MS
https://linustechtips.com/topic/920268-surge-protectorups/#findComment-11291601
