I have a question about ethernet cables. I was wondering what is the difference between CAT 5, CAT 5e, CAT 6 and CAT 7 for gaming? I am currently using a CAT 5e and sometimes I feel laggy and keep getting these connect error when I play games like overwatch and rainbow 6, will a CAT 6 or CAT 7 make them go away?
Image result for overwatch connection issue icon
Thanks in advance
https://linustechtips.com/topic/919306-ethernet-cables/
Unless it's a very long run (hundreds of meters) or a very shitty cable, no, it won't help.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/919306-ethernet-cables/#findComment-11268673
The category-rating has to do with how the wires run inside the cable and what sort of shielding against noise there is. With the 802.3bz-standard, the Cat5e-cabling you have is rated for 2.5Gbps, Cat6 goes up to 5Gbps, Cat6a to 10Gbps and Cat7 isn't a proper standard in the first place. If your cables are actually of good quality and they aren't damaged inside, they should make literally zero difference to your games -- it's some other part of your network that does it, including your ISP.
https://linustechtips.com/topic/919306-ethernet-cables/#findComment-11268677
Just now, WereCatf said:
The category-rating has to do with how the wires run inside the cable and what sort of shielding against noise there is. With the 802.3bz-standard, the Cat5e-cabling you have is rated for 2.5Gbps, Cat6 goes up to 5Gbps, Cat6a to 10Gbps and Cat7 isn't a proper standard in the first place. If your cables are actually of good quality and they aren't damaged inside, they should make literally zero difference to your games.
I'd note that Cat6 can do 10GBASE-T, but only up to 55m.
https://linustechtips.com/topic/919306-ethernet-cables/#findComment-11268686
Yeah, there's also an exception for cat5e where it can do 5Gbps, but I figured the OP doesn't really need to know about all the exceptions.
https://linustechtips.com/topic/919306-ethernet-cables/#findComment-11268702
Connection errors can be caused by numerous things, you could try and replace the network cable with a CAT6 cable it shouldn't be that expensive.
Other possible issues could be your router/modem that is dying or that the internet cable itself is damaged causing network interrupts.
https://linustechtips.com/topic/919306-ethernet-cables/#findComment-11268705
Don't forget Cat8 exists (or is coming soon) which can do 25Gbps and 40Gbps up to about 30 meters :D
Edit:
On topic, if the cable is crap, pinched, damaged, etc. then it can cause errors in the line even though the connection works.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/919306-ethernet-cables/#findComment-11268711
Bah, humbug! I'mma stick to my pigeons for carrying my TCP/IP-packets!
https://linustechtips.com/topic/919306-ethernet-cables/#findComment-11268718
And I'll take my 400Gb QSFP-DD optics for my light speed TCP/IP packets :D
Prior Build Log/PC:
https://linustechtips.com/topic/919306-ethernet-cables/#findComment-11268722
