LG 49UJ620V wall mount?
6 minutes ago, Tadziunia said:Hey guys , i wan tot buy TV, but am not sure it's possible to mount it on the wall. I can't find any info or instruction for that. Any ideas ?
TVs are commonly wall mounted through what is known as a VESA mount. You will need to find a VESA wall mount with compatible dimensions as your model of TV. It's faily easily to install if you can operate a drill and can find studs in your wall, but if you're unsure about installing it on the wall, consult a professional TV installer.
I couldn't find any information about whether or not this model of TV supports VESA mount in its LG manual, however I did find information for it on another website. This suggests that your TV will support wall mounting through a 200x200mm VESA mount. Feel free to contact the store you are purchasing it from to confirm that it does indeed support VESA mounting.
https://www.displayspecifications.com/en/model/dd54e97
