Hello, Im currently working on my first build and learning a lot. Id like to know your thoughts on the parts list i put together https://pcpartpicker.com/user/Brandon_DS/saved/ksPCyc . I plan on using the system for 3d content creation using programs like modo , blender , maya, keyshot , marvelous designer, photoshop , photo scan Pro, Zbrush and other graphic/cpu intensive programs. I would also like to be able play games like Pub-g , tomb raider , Battlefield games, Far cry ,and racing games like dirt with a good amount of frames preferably at 2k resolution. I plan on running 3 monitors at some point one at 2k and the others at 1080p
 Im currently using a 2011 macbook pro that has had gpu problems in the past and isn't cutting it when it comes to working on 3d projects . I am In the US and i like the price its currently at which is $1454.90, Id be willing to spend a little more if its necessary for what i want to use it for. I also have another list thats slightly cheaper  at $1376.81 with a cheaper ssd and different ram that wouldn't look as nice on the exterior but would perform about the same if im correct https://pcpartpicker.com/list/JQ4rV6 . I plan on adding more ram and storage later down the line as well.
Please let me know your thoughts on what i put together , how i can improve it, or if there are any problems with it, Thanks!
https://linustechtips.com/topic/919017-first-contentgaming-pc-build/
Use the stock cooler instead of the added cooler, about the same in performance
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
Looks good, but i would use the stock cooler.  Also i wouldnt cheap out on the Storage, as all your important stuff is on there and the cheap stuff fails faster. Also if you don't do those stuffs as a hobby, but as a job i would get some sort of backup, for example run a raid 1 or a hdd as a backup. You can't explain to a client that your storage failed, because deadlines are deadlines.
BUILD SOMETHING LIKE THIS....
CPU: AMD - Ryzen 5 2600X 3.6GHz 6-Core Processor  ($229.99 @ Amazon)
Motherboard: ASRock - X470 Master SLI/AC ATX AM4 Motherboard  ($143.98 @ Newegg)
Memory: Team - Dark 16GB (2 x 8GB) DDR4-3000 Memory  ($159.99 @ Newegg)
Storage: SanDisk - SSD PLUS 240GB 2.5" Solid State Drive  ($69.89 @ OutletPC)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.79 @ OutletPC)
Video Card: MSI - GeForce GTX 1080 8GB DUKE OC Video Card  ($599.99 @ Newegg)
Case: Phanteks - Eclipse P300 Tempered Glass ATX Mid Tower Case  ($58.05 @ Newegg)
Power Supply: EVGA - SuperNOVA G3 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($73.98 @ Newegg)
Operating System: Microsoft - Windows 10 Pro Full 32/64-bit  ($35.00)
Mouse: Logitech - G502 Proteus Spectrum Wired Optical Mouse  ($45.99 @ Target)
Total: $1476.65
Generated by PCPartPicker 2018-04-21 17:40 EDT-0400 I
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
Total: $1476.65
Thanks! I think ill be going with that build ,though i may change the case for a Fractal design Meshify C Tg or the NZXT s340 elite which one would you guys choose or is there another in those price ranges that you like more let me know and thanks again!
Nzxt s340 has pretty bad air flow...
I'll suggest to go with something like phanteks eclipse p400 or meshify c
SSD TIER LIST
CPU - Ryzen 7 3700X
that's literally worse
Full Specs
Helios EVO (Main):
Delta - Laptop
SSD TIER LIST
CPU - Ryzen 7 3700X
If i do go with the meshify c the case specs says the max gpu length is 315mm and that 1080 is 312mm isnt that tight? I want to buy two more case fans and im not sure if there would be enough space to fit them up front , which is why i was looking at the NZXT s340 e with max gpu length of 364mm. I also really like the look of it , is its cooling that bad? Thanks for all the help btw
My 980ti used to get pretty hot in it.....
SSD TIER LIST
CPU - Ryzen 7 3700X
TRY ONE OF THESE CASES..
  1. Phanteks EVOLV mATX: http://geni.us/EVOLVMATX
  2. Fractal Meshify: http://geni.us/mBlpdBh
  3. NZXT H700i: http://geni.us/9yqP8tf
  4. BeQuiet Dark Base 700: http://geni.us/DARKBASE
  5. Phanteks Enthoo PRO M SE: http://geni.us/PROMSE
  6. CM Maker 5T: http://geni.us/F4W4
SSD TIER LIST
CPU - Ryzen 7 3700X
Not sure why everyone is recommending the 2600x.  The 2600 is the same processor and it cost s 30 dollars less. You could use that money for a bigger SSD.  Also, the G. Skill sniper X 3600 is a better value for RAM.
I edit the shit out of my posts.  Refresh before you respond.
Better cooler afaik
Full Specs
Helios EVO (Main):
Delta - Laptop
You could always go with a smaller 1080 if it bothers you, such as the Asus Rog Strix, Gigabyte G1 or one of the various EVGA models as they are all dual fan so come in at around 260mm or so.
**Do you already own the 1070 ti in your initial post ? If so then no reason to change it for a 1080**
I was concerned about fitting the graphics card in there with a front fan but the case specification was 315mm with the front fan so it might be tight but it should fit. Than i finally decided to go with the Meshify C , i was really torn because the s340 elite looks so good but ill get over it lol.
Other than that this is what its at https://pcpartpicker.com/user/Brandon_DS/saved/Qg7VYJ
I changed the case to the meshify C and added two120mm fans that has an airflow of 51.4-87 CFM for only 8.99Ea. If every thing Looks Good than ill see what parts i can buy locally and start ordering the rest tomorow!
One last thing , Comparing the 1080 and 1070 ti https://www.extremetech.com/gaming/258357-nvidias-new-gtx-1070-ti-neatly-splits-difference-gtx-1070-1080 what would you choose considering the 1080 is now $100 more for slightly better performance? I know its a personal preference thing but would choose the msi 1080 https://www.newegg.com/Product/Product.aspx?Item=N82E16814137084&ignorebbr=1&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker, LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID= or would it be a good idea to just save $100 and this https://www.newegg.com/Product/Product.aspx?Item=N82E16814932013&cm_re=1070_ti-_-14-932-013-_-Product  .  Please let me know your thoughts i would greatly appreciate it!
I would change this. SSD Plus is mediocre at best. Meanwhile, MX500 is $3 more but way better. I agree with everything else.
https://pcpartpicker.com/product/4mkj4D/crucial-mx500-250gb-25-solid-state-drive-ct250mx500ssd1
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
