Hey guys, I just bought APC Back-UPS 1100VA ( USD $90) for my system. The specs sheet stated that the output from this UPS is stepped sinewave.
Can a stepped sinewave damage my PSU (Seasonic Prime Titanium 650w)?
I've read that PSU with active PFC can be damaged by a stepped sinewave however there are no actual proof of it.
Should I change my UPS to a sinewave one? Costs around $200 ($300) more to get the sinewave one.
Thank you!
[CPU] Intel i7 8700K [Motherboard] Asus ROG Maximus X Hero Z370 [RAM] Corsair Dominator Platinum 3000 Mhz [GPU] Asus Strix 1080 Ti OC [Case] Phanteks Enthoo Evolv ATX Tempered Glass [Storage] 250GB Samsung 960 Evo M.2 + 250GB Samsung 850 Evo + 1TB WDC Blue [PSU] Seasonic Prime 650W [Display] Aorus KD25F + Acer Predator XB271HU [Keyboard] Corsair K65 Rapidfire Cherry MX Speed [Mouse] Endgame Gear XM1 + Logitech G303 [Sound] Sennheiser Game One [OS] Windows 10 64 bit
https://linustechtips.com/topic/918564-stepped-sinewave-damage-psu/
one guy here said
Quote
I just finished my Engineering Electrical Systems unit at university last semester. In theory, modified sine wave wont be as efficient as pure sine wave, but it shouldn't damage anything - especially if you have a quality power supply. As far as i can tell, the only damage would be likely to arise from an increased temperature in the PSU - but PSU's rarely seem to overheat.
Also, if you get a power-board with EFI/RFI filtering, it _might_ help to reduce the buzzing. I'm not sure, but what "jose" said makes sense to me.
RoD
BtW, i think what duckzilla said about the guarantee was correct, so you'r probably okay even if something does go wrong.
41 minutes ago, Electronics Wizardy said:
How often are you running on battery? Its only stepped sine wave when on battery, and doing it for a few hours a year won't make a difference.
Usually I turn off my pc when there is an outage. However the PSU does emmit a buzzing sound while on battery.
39 minutes ago, Technomancer__ said:
one guy here said
Thanks for the info!
