(Solved)Need help with identifying watercool Components
Solved by Oshino Shinobu,
Radiator: XSPC EX360 White
CPU Block: Thermaltake Pacific W3
I'm not sure what reservoir that is, but the pump is a Laing D5 vario (branded by Alphacool)
EDIT: Found it. It's a PrimoChill CTR Phase 2 D5 enabled reservoir. I'd guess it's the 240mm version by the looks of things.
http://www.thermaltake.com/products-model.aspx?id=C_00002883
http://www.xs-pc.com/radiators-ex-series/ex360-triple-fan-radiator-white
