Hi guys, I tried to build a PC with these specs
Intel xeon x3440 processor
Zebronics h55 motherboard
6 gb of ram  (I dont know if its ecc or non ecc ram)
750 ti graphics card
corsair vs450 powersupply
Problem is it doesnt show any display on screen. I tried everything possible, cmos battery and all, even gave it to a repair shop. They tried motherboards from biostar with h55 chipset and it still gives no display on screen. By now i am thinking the processor might be a dead one but also thinking whether the motherboards that were tried were incompatible. the repair shop gave up and i am left with a non functional pc. I used my parents money on it and i dont want it to go waste. Can anybody suggest me a way out? Could it be motherboard compatibility issue or the processor is dead? we tried with an h55 chipset motherboard but it didnt work. Should i try with a p55 chipset motherboard? or should i just buy another processor. Also one more thing do i need special ram to run this processor?? Thanks alot guys.
edit: Different ram and psus were tried but still same no display problem. So its something related with the processor or motherboard.
https://linustechtips.com/topic/918242-pc-not-working-need-expert-advice/
that cpu will work just fine with ecc or non-ecc ram. Does your PC turn on in the first place? have they tried using a different PSU? does the mobo speaker give out any beep codes?
Have you tried going through something like this list? It could help - tech shops aren't known as being perfect.
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
Yes i have followed most of it except the static. The biostar motherboard should support my processor. I tried ram with all combinations possible. I got a mobo speaker installed but it doesnt beep at all. Cpu power is connected properly in the 4 pin. I aligned the processor properly without fail. there are bumps in my case which always keeps the motherboard raised so i don't think i need those standoffs. Yes i put the power cable for video card properly. Tried with different motherboards outside the case still same problem.
