What HDMI cable do I need?
Solved by Oshino Shinobu,
Just now, Teuminator said:thanks. This one supports at least 1080p 120hz, but 4k is a lot more than that. If it supports 4k 60hz, it will show that in nVidia Control Panel?
If the cable supports 1080p 120Hz, it should support 4K as it's category 2, which is the highest bandwidth HDMI cable available right now. Category 1 cables cap out at 1080i, so it's definitely not one of those.
Should work just fine.
