Hey, i am looking to buy this laptop for school
https://www.amazon.com/gp/aw/d/B06XDY3T7T/ref=ox_sc_saved_image_1?smid=A3S03JT7479WJ5&psc=1
is this a good laptop for cad
Here are the specs I need
System requirements
Stabicad for Revit
The system requirements of Autodesk Revit products apply to Stabicad for Revit.
  • Stabicad for Revit supports Revit 2017 - 2019
  • Only 64 bit
Recommended processor speed: Intel i5 / i7 or similar. (A processor with a high clock rate is preferred over a processor with more core's)
Recommended internal memory Revit: 16 GB
Recommended free disk space Revit: 100 GB
Advice video card for Revit: Nvidia Quadro K4000 series or equivalent. Check for certified video card drivers the following the link: https://knowledge.autodesk.com/certified-graphics-hardware
https://linustechtips.com/topic/917666-laptop-for-cad/
No, the APU sucks. What's your budget? Where are you from? Any special requirements?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/917666-laptop-for-cad/#findComment-11252500
I live in Europe under 650 euros is my budget. Don't have special requirements
Here is another one I found https://www.amazon.com/gp/aw/d/B06XFG7157/ref=ox_sc_saved_image_3?smid=A27Q4NXVM8ES3L&psc=1
https://linustechtips.com/topic/917666-laptop-for-cad/#findComment-11252654
Mind providing some links of online stores in your country?
Desktop specs:
https://linustechtips.com/topic/917666-laptop-for-cad/#findComment-11252736
Your budget is quite low. Consider used/refurbished business laptops or bumping up your budget if you prefer new.
Desktop specs:
https://linustechtips.com/topic/917666-laptop-for-cad/#findComment-11253783
Yeah I was already am looking for used laptops
But can I buy a laptop with a 1050 4gb and a i5 HQ processor for Cad
https://linustechtips.com/topic/917666-laptop-for-cad/#findComment-11254184
Like which model? 7300HQ is slower than 8250U.
Desktop specs:
https://linustechtips.com/topic/917666-laptop-for-cad/#findComment-11254195
6 hours ago, Need_a_name said:
7300hq but I don't think I need a really powerful CPU for the program it says it needs a i5 of i7.
And you don't need 1050 GPU for that too
Just get a used workstation laptop with Quadro GPU. Your budget is really low.
Desktop specs:
https://linustechtips.com/topic/917666-laptop-for-cad/#findComment-11260880
