I have an 1155 Z68 motherboard, I plan to game at 1080p and need a sufficient cpu, I was thinking of the 2600k, but I don't know if that would be enough for gaming, would a 3770k be better?
the 2600k would be about $100 on eBay vs the 3770k @ $200.
I'm fine with overclocking a tad.
also I have a free sync monitor @ 144hz, would a used rx 580 be a  good choice at this date, or should I wait for the 600 series to release (or maybe the 20xx series)
https://linustechtips.com/topic/917310-cpugpu-help/
3 minutes ago, hconverse02 said:
The 2600k would be plenty for gaming, the 580 used would still be around $300, so it depends on if you really need freesync, because a new 1060 6gb costs about the same and has a warranty.
if I were to give up free sync should i go for like a used 1070/ 980ti for $50-75 more?
https://linustechtips.com/topic/917310-cpugpu-help/#findComment-11248502
It might be hard to find a used 1070 for $400, but I don't doubt that you could.  I don't see why not, but if you can find a rx 580 8gb for under $300, go for it, because it will still be a few months until prices normalize.
https://linustechtips.com/topic/917310-cpugpu-help/#findComment-11248508
which xeon, i'm not really that informed about them
answered before i asked lol:D
1 minute ago, ZcanKal said:
Xeon E3-1240, it's about $60 on ebay, I have one and just because of my old CPU's architecture (piledriver) the Xeon WAY outperforms it.
https://linustechtips.com/topic/917310-cpugpu-help/#findComment-11248521
The 580 is pretty much the equivalent of Nvidia’s 1080. It’s really good.
https://linustechtips.com/topic/917310-cpugpu-help/#findComment-11248527
E3-1280 or i7-2700k are going to be the best price/perf chips.
The E3-1280 can run with a 105mhz BCLK giving 3675mhz base speed, 3780mhz all core turbo, and 4095mhz max turbo.  Adjustments to voltages are usually not needed.
i7-2700k can be overclocked to ~4.5ghz at least without much drama.
E3-1280 will be just below Ryzen 4c/8t levels of performance in gaming with the overclock.
i7-2700k ends up a hair faster than that.
RX 580 is about the same as a GTX 1060, marginally slower in some cases and marginally faster in others.
https://linustechtips.com/topic/917310-cpugpu-help/#findComment-11248530
ok, whats your take on the rx 580?
Its good for 1080p in most if not all cases.  If you can get a 6gb GTX 1060 for cheaper, do that instead, only mentioning this because AMD GPU's have not seen prices drop off as much as the GTX 1060 yet.
https://linustechtips.com/topic/917310-cpugpu-help/#findComment-11248580
I just got an Rx 580 4gb nitro+ for $240, 8gb 480's go for less quite often as well.  You can even snag a 1080 for around 400 - 550 if you watch closely
Go to r/hardwareswap and don't be a dunce (no friends and family, check ban list before buying)
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/917310-cpugpu-help/#findComment-11248594
