download speed differences
Just now, Trocify said:ok now i'm testing it by downloading gears 4 and it's staying around the 10 to 11 mark and i pay for up to 100mb plan with cox the preferred 100 am i missing something but this is an upgrade to the old 2-3 mbps i was getting with my old router so maybe a better router or wifi adapter? cause the new router supports the 100mbps plan
If you're downloading over WiFi then there will be some speed loss so a different adapter could close the gab but if you're getting between 10 and 11 MBps (80 to 88Mbps) then you're really close to the 100Mbps mark. You'll rarely get exactly as advertised but if you're within spitting distance then it's good and they usually won't do anything. The one thing nobody really talks about is overhead. Each packet of information will have some overhead that's not counted by the application but does count towards the download speed you get so generally if you're within a few Mbps then you're good.
