Still need to clean up the wiring a bit with ties, waiting for Bitspower RGB LED strips for the graphics card blocks to arrive, and unsure if I want to leave the pump/res mounted on the side or move it down to the bottom/middle area. Also debating if I should get a tempered glass panel for the left side (bought 1 to see how it fit on the right side but there's a 3-4mm gap all along the top edge that I'm worried will let in a lot of dust).
Thanks for the tips and inspiration here guys!
main water cooling parts:
EK Coolstream XE 480 x 2 in series
EK-XRES 140 Revo D5 RGB PWM (swapped to taller EK-RES X3 - Tube 250 (204mm)
EK-FB ASUS R5-E10 Monoblock - Acetal+Nickel (couldn't find the acrylic one anywhere)
Bitspower Titan V graphics card blocks + 2 card GPU bridge
8x 3000 rpm Noctua Industrial PWM 120mm fans on the rads
added in 2 2000 rpm Noctua industrial PWM 120mm fans on the floor to pull air up in towards the rad, and a 2000 rpm 140mm on the rear bottom opposite side of the PSU also as an intake.
This way the exhausts are the radiators and a single 140mm Noctua industrial 2000rpm PWM fan on the upper rear, hopefully to create a little bit of positive pressure to keep dust down.
HEDT: i9 10980XE @ 4.9 gHz, 64GB @ 3600mHz CL14 G.Skill Trident-Z DDR4, 2x Nvidia Titan RTX NVLink SLI, Corsair AX1600i, Samsung 960 Pro 2TB OS/apps, Samsung 850 EVO 4TB media, LG 38GL950G-B monitor, Drop CTRL keyboard, Decus Respec mouse
Laptop: Razer Blade Pro 2019 9750H model, 32GB @ 3200mHz CL18 G.Skill Ripjaws DDR4, 2x Samsung 960 Pro 1TB RAID0, repasted with Thermal Grizzly Kryonaut
Gaming Rig: i9 9900ks @ 5.2ghz, 32GB @ 4000mHz CL17 G.Skill Trident-Z DDR4, EVGA RTX 2080 Ti Kingpin, Corsair HX1200, Samsung 970 EVO Plus 2TB, Asus PG348Q monitor, Corsair K70 LUX RGB keyboard, Corsair Ironclaw mouse
HTPC: i7 7700 (delidded + LM), 16GB @ 2666mHz CL15 Corsair Vengeance LPX DDR4, MSI Geforce GTX 1070 Gaming X, Corsair SFX 600, Samsung 850 Pro 512gb, Samsung Q55R TV, Filco Majestouch Convertible 2 TKL keyboard, Logitech G403 wireless mouse
https://linustechtips.com/topic/915897-nearly-finished-first-open-loop/
well it's a good first attempt. if you've got no leaks, i'd call that a success!
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
thanks! I know the main in and out lines from the pump are hideous but I wasn't sure what to do with them since i need to be able to pull it out to bleed the air properly.
No leaks, except that I was an idiot when swapping to this Primochill Vue fluid and forgot to close and cap the drain valve so I poured Vue all over the Titan V's and motherboard. There was much cursing.
Luckily drying everything off for a day seemed to be fine.
