https://linustechtips.com/topic/915852-need-laptop-help-asap/
1 minute ago, DreamingInBlood said:
everything I've read about the asus says it has absolutely terrible cooling
depends on how much stress you will be putting on it. I use asus and can run fallout 4 on extreme graphics and its totally fine. However the laptop you will be buying won't be able to play extreme graphics you shouldn't have a problem with heating.
https://linustechtips.com/topic/915852-need-laptop-help-asap/#findComment-11235395
Yes. Not terrible when you're gaming. But it's still mediocre. MSI GF is basically a rename of the old GE and it doesn't have great thermals as well.
Where are your from? What's your budget and what are your requirements?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/915852-need-laptop-help-asap/#findComment-11235442
US, I want either a 15.6 or a 17.3 I don't want to spend more than $1,00 for a 15 or $1,200 for a 17. anything with a max q is out of the question like the dell 7577
https://linustechtips.com/topic/915852-need-laptop-help-asap/#findComment-11235500
You can tweak it to match a regular 1060 due to the good cooling in the 7577. Just be aware of any VRM throttling issues.
Consider these options, all with 1060 6GB GPU:
Clevo P650HP6 - promotion in Newegg
Clevo N950KP6 - promotion in Newegg, desktop CPU, may need repaste
Dell 7577 (Max-Q) - needs GPU tuning, may need thermal pads on VRMs, entry level IPS
Lenovo Y720 - may need repaste, entry level IPS
Lenovo Y520 (Max-Q) - needs GPU tuning, entry level IPS
Or wait for more CFL-H options like Dell G3,G5,G7
Undervolting CPU & GPU and repaste are highly recommended for every laptop.
Edit: For $1299 you can get a P650HS (Powerspec 1510) with 1070 GPU from Microcenter
Desktop specs:
https://linustechtips.com/topic/915852-need-laptop-help-asap/#findComment-11235568
What about the Acer Predator Helios 300 17.3”?
https://linustechtips.com/topic/915852-need-laptop-help-asap/#findComment-11239393
Mediocre thermals. Not recommended.
Desktop specs:
https://linustechtips.com/topic/915852-need-laptop-help-asap/#findComment-11239483
Don’t want the dell 7577 because it’s a 15”. But I want a big name 17” like asus, msi, Acer or something like that. I plan on undervolting and doing new thermal paste on whatever I get.
https://linustechtips.com/topic/915852-need-laptop-help-asap/#findComment-11239663
Brand is less relevant in laptops. In fact the 'big names' don't manufacture their own laptops, this is done by ODMs like Pegatron, Compal, Quanta and also, Clevo. If you want a good 17 inch gaming laptop then you might want to bump up your budget. Or wait for CFL-H options like Dell G3,G5,G7
Desktop specs:
https://linustechtips.com/topic/915852-need-laptop-help-asap/#findComment-11239805
