I need a new ethernet cable and I previously had a Cat 5e cable and I have 100mpbs down which I think is near the peak capability of that wire so I figured I would get Cat 6 since it looks cheap. I was looking at this cable and I would like to know if the 25ft variant is a good cable and sufficient enough for gaming and downloads.
 https://www.amazon.com/AmazonBasics-RJ45-Cat-6-Ethernet-Patch-Cable-5-Feet-1-5-Meters/dp/B00N2VIWPY/ref=pd_sbs_147_6?_encoding=UTF8&pd_rd_i=B00N2VILDM&pd_rd_r=SYA83PTZPNXHCPKV5Y7A&pd_rd_w=753S7&pd_rd_wg=Mnh5g&refRID=SYA83PTZPNXHCPKV5Y7A&th=1
https://linustechtips.com/topic/915491-does-this-cable-work-fine/
yeah go for it,
i7-8700k @ 4.8Ghz | EVGA CLC 280mm | Aorus Z370 Gaming 5 | 16GB G-Skill DDR4-3000 C15 | EVGA RTX 2080 | Corsair RM650x | NZXT S340 Elite | Zowie XL2730
If you’re looking for something shorter (for the office/laptop) I can attest that
Tbmax Retractable Network Cable Cat 6 Ultra Flat, With Protection Case Lightweight and Compact Thin Cat6 Ethernet Cable RJ45 Connectors for Travel and Hotel- Ethernet Cable 5.7 Ft When Retracted White https://www.amazon.com/dp/B015E69410/ref=cm_sw_r_cp_tai_p8PZAb9VZQFPA
works just fine. I use it with my Mac all the time
AMD Ryzen 3950x under a Noctua D15S, 32 Gb G Skill FlareX 3200 DDR4 running at 3200 CL14, Gigabyte Aorus Pro 570 Wifi, Gigabyte 2070 Super hooked to a Dell U2718Q 4k HDR monitor & an Acer 1440p 144hz IPS panel of some kind, an Inland 1 TB M.2 PCIE 4 main drive, a Samsung NVME M.2 250Gb, WD Blue 500Gb  and 1 TB SSDs, Corsair RMX750, Rainbows and butterflies...
