Hi, I'm thinking for about a month about this project.
In my home town they offer 1Gbps for about 14 us dollars. We currently have 3 ISPs who can provide those services.
I'm looking to get all 3 connections and bond them together for a total of 3Gbps. Is this possible and if so what equipment do I need? I was looking yesterday without a clue at Ubiquiti's website.
https://linustechtips.com/topic/915266-3gbps-bonding-solution/
Linus did a video where he joined two connections at his home. I don't know about 3 connections though.
But dude seriously, you don't need 3Gbit internet!!!!
Most people's computer drives aren't even that fast!
You don't need this. I don't know why you need more. Most people don't measure they're internet speed with GBits. They use something called Mbits just in case you hadn't heard about this.
What on earth are you planning to do with this?
BTW, If you really plan on doing this, you need to get the following:
https://www.amazon.com/StarTech-com-Express-Gigabit-Ethernet-ST10000SPEX/dp/B00LPRS36K
https://rog.asus.com/articles/networking/bring-10gbit-ethernet-home/
PC Specs:
CPU: Intel Core i7-12700K 3.6 GHz 12-Core
CPU Cooler: Corsair iCUE H150i ELITE CAPELLIX 75 CFM Liquid CPU Cooler
Motherboard: Asus ROG STRIX Z690-E GAMING WIFI ATX LGA1700
RAM: Kingston FURY Beast 32 GB (2 x 16 GB) DDR5-5200 CL40
Storage: Boot Drive: Samsung 960 Evo 250GB M.2 NVMe SSD
               Other Storage: Mass Storage: Western Digital Caviar Blue 1TB 7200 RPM, Western Digital Caviar Blue 2TB 5400 RPM, Scratch Disk: Intel X25-E SSDSA2SH032G1 32GB SATA II SSD, Backup Drive: Seagate ST3160318AS 160GB HDD
GPU: Asus GeForce RTX 3080 Ti 12 GB ROG STRIX GAMING OC
Case: Corsair 5000D AIRFLOW ATX Mid Tower
PSU: Silverstone Strider Platinum S 1000 W 80+ Platinum Certified Fully Modular ATX
OS: Windows 11 Pro 64-Bit
Monitors: Primary: Samsung S34E790C 34" 3440*1440 60 Hz UWQHD; Secondary: LG 34UM58-P 34" 2560*1080 75 Hz UWFHD; Tertiary: BenQ GL2460 24" 1920*1080 60 Hz FHD
Keyboard: Corsair K70 Mk. 2 RGB Gaming Keyboard - Black
Mouse: Corsair M65 Pro RGB FPS Gaming Mouse - Black, Logitech MX Master 3
Headphones: Corsair VOID PRO Surround Cherry 7.1ch
Speakers: Logitech Z213 7W 2.1ch
Laptop:
Asus Zenbook Pro 15 (UX535Li-E2018T) with Intel Core i7-10750-H 12MB @ 2.60GHz (Turbo @ 5.0 GHz), 16GB (2 x 8GB) DDR4 2933 MHz SODIMM and Intel(R) UHD Graphics; NVidia Geforce GTX 1650-Ti with Max-Q Design, using WDC NVMe PC SN730 SDBPNTY-1T00-1102, on a 96-Wh battery
NAS Specs:
Make & Model: QNAP TS-1277
CPU: AMD Ryzen 5 1600 @Stock
Hard Drives: x8 WD Red 2TB
SSDs (2.5"): x1 Samsung 850 Evo 250GB V-NAND (cache drive)
M.2 SSDs: None
RAID Configuration: RAID 6 (excluding SSD)
Total Storage: 12TB
Expansion Cards: None
https://linustechtips.com/topic/915266-3gbps-bonding-solution/#findComment-11229826
Anyway if you wanted that speed you would have to run 3 cables assuming that each cable can only do 1gbit.
PC Specs:
Laptop:
NAS Specs:
M.2 SSDs: None
Total Storage: 12TB
https://linustechtips.com/topic/915266-3gbps-bonding-solution/#findComment-11229833
The above video you linked requires both connections to be from the same ISP and the ISP needs to configure their end for bonding. Aggregating multiple ISP connections from different ISPs or without ISP side configuration will achieve basically nothing, unless you have 3 people simultaneously wanting to use 1Gbps each fully.
https://linustechtips.com/topic/915266-3gbps-bonding-solution/#findComment-11229841
Ahh ok.
PC Specs:
Laptop:
NAS Specs:
M.2 SSDs: None
Total Storage: 12TB
https://linustechtips.com/topic/915266-3gbps-bonding-solution/#findComment-11229843
When I clicked on this thread I thought it was something to do with SATA 3GBits/s. But now I realised it's about internet speed.
PC Specs:
Laptop:
NAS Specs:
M.2 SSDs: None
Total Storage: 12TB
https://linustechtips.com/topic/915266-3gbps-bonding-solution/#findComment-11229845
So what are you saying is that I will achieve 0 increase in speed, I will just have more bandwidth?
https://linustechtips.com/topic/915266-3gbps-bonding-solution/#findComment-11229921
Yep, if you ran a speed test all you'd get is 1Gbps. You could do that on 3 devices at once and all 3 would each get 1Gbps though.
https://linustechtips.com/topic/915266-3gbps-bonding-solution/#findComment-11229981
I remember seeing some modems in the past that had similar capabilities. E.g. allowing multiple connections to be used. But while they could be used simultaneously, it was more designed as a failover. So if your cable/dsl connection went down, it would switch over to 4G.
You can definitely get corporate grade routers (think expensive CISCO equipment) that can manage multiple links, but as others have stated, it would increase bandwidth, not top speed. So if your first 1gb link was saturated, it could start using the second link and so on. Multiple devices can use multiple links, which could improve your situation through not having to share bandwidth, but your primary PC won't suddenly be getting 3gbs instead of 1gbs.
Also, unless you are hosting content for others, I don't see why currently anyone would need that level of bandwidth at home.
https://linustechtips.com/topic/915266-3gbps-bonding-solution/#findComment-11233498
Of course I don't need it, I don't even need 1Gbps but why not do it? I'm searching google for load balancing routers with 3 SFP+ or GPON connections. Maybe I'm doing something wrong. After I order my connections I will have 3 cables who aren't RJ45 cables. They are really thin and with an elongated connector. I'm not sure if they are SFP+ or GPON.
Even if I only increase my bandwidth I still want to do it. But I really don't know what to get in order to make it work.
https://linustechtips.com/topic/915266-3gbps-bonding-solution/#findComment-11234220
Money....It must be nice to not care about money that much.
No you will have RJ45 connections. You will never receive a bare fiber connection. The ONT is what converts the light almost exactly the same way a modem converts the signal on Cable/DSL.
This project is way to complicated for a "fuck it, lets do it". Especially when you need to understand way more than basics in networking.
https://linustechtips.com/topic/915266-3gbps-bonding-solution/#findComment-11234401
Yes, they will give me a device that converts the GPON to RJ45 outputs but I was thinking I can buy a load balancing router with multiple GPON inputs.
https://linustechtips.com/topic/915266-3gbps-bonding-solution/#findComment-11234858
Again, you obliviously dont understand how this works. They are not going to give you a fiber and thats not how GPON works.
https://linustechtips.com/topic/915266-3gbps-bonding-solution/#findComment-11234864
Firstly, you need to know what technologies those companies are using to provide Gbit connectivity, if they are installing their own fiber to the premises then its possible.  However if they are using DOCSIS 3.1 for example you will only be able to have 1 ISP at the property at once.
3Gbit seems like overkill, I dual-wan and load balance their bandwidth myself but that's for different reasons
Please quote or tag me if you need a reply
https://linustechtips.com/topic/915266-3gbps-bonding-solution/#findComment-11234989
Have you even checked that 3 fibre lines to a residential address is even allowed? Usually it's not a case of willing to pay for it, often it's simply not allowed. If they do allow it then you'll get 3 ONTs.
Without a business connection an ISP isn't going to allow you to bring your own GPON networking equipment and they won't give you the required configuration to make it work, your miss configurations will effect their networks so you'll get a very quick and abrupt "No we will not allow this".
So the first step before you do anything is find out if you can actually get three connections provisioned to your property at all.
https://linustechtips.com/topic/915266-3gbps-bonding-solution/#findComment-11235222
No ISP in their right mind would ever let anyone install their own GPON equipment.
https://linustechtips.com/topic/915266-3gbps-bonding-solution/#findComment-11236778
Yea, agree to a point. We would be allowed to, not that we would use GPON like ever. We're that sort of in between being a ISP and not being one, a defacto ISP by nature of who we are and our requirements etc.
We house equipment on behalf of a couple of ISPs anyway and are a major aggregation point for the area, plus have some odd peerings due to that. Guest hotspot networks not operated by us but on our campus isn't true internet traffic in regards to traffic destined to our network, makes for some interesting traffic flows lol.
https://linustechtips.com/topic/915266-3gbps-bonding-solution/#findComment-11236853
And thats the thing, why would an ISP every give a GPON connection over a Gig Eth.
Sweet! So do you guys plan of becoming an ISP? We are a small but large ISP so to say i guess...lol.
https://linustechtips.com/topic/915266-3gbps-bonding-solution/#findComment-11236880
No, we're a university but have campuses that span 3 major areas of the North Island (main population location of NZ), Wellington, Auckland and Palmerston North. We have all the equipment, multiple ASNs (each /16 in associated subnet size), multi homed peerings etc, all the basic ISP jazz infrastructure wise but legally we aren't allowed to and wouldn't want to anyway.
GPON is great for residential, nothing else. Both are far too slow for us anyway.
GPON's main attraction is it's multi services capability and isn't reliant on IP only. GPON can handle POTS phone and has a dedicated wavelength for IPTV.
https://linustechtips.com/topic/915266-3gbps-bonding-solution/#findComment-11236936
Bonding over WAN is not what you think it is. A router capable of routing 1gpbs fully is expensive, CPU wise and hardware wise let alone 3gbps.. Bonding 3 WAN connections does not work in the same was as a lan environment. Like someone else posted, both sides need to be "aware" of the bonding in order to achieve 3gpbs. What routers are doing when they bond multiple ISPs is route certain traffic through certain IPs. So VOIP traffic go through IP #1, Https through IP 2 and so on. What you are asking is impossible without the ISP helping out lol
Sorry man
https://linustechtips.com/topic/915266-3gbps-bonding-solution/#findComment-11239536
