Yo. Im having some trouble with my computer i upgrading the power supply from a 500 to a 750 it was not turning on but i got it working now but now it freezes in the window screen before loging in or it will not find a source on my screen. but when i put the old power supply back in it works fine. please help
https://linustechtips.com/topic/915088-please-help/
Make sure you recheck all of your cable connections. If you still have warranty with it, you can always just RMA.
*psst* next time, try to make your text legible for dark theme users. ty
"May your frame rates be high and your temperatures low"
I misread titles/posts way too often--correct me if I don't.
https://linustechtips.com/topic/915088-please-help/#findComment-11227922
1 minute ago, AndreasRitter said:
is there a good connection and did you plug in all the cables correctly?
yes all cables are in right and i even switched them out for other ones and still does the same thing
https://linustechtips.com/topic/915088-please-help/#findComment-11227930
4 minutes ago, kb5zue said:
Is the computer a pre-built?  If so, it's possible the connections on the old power supply are proprietary.
yea, it is a pre-built. so that means it wont work because i bought a gtx 1060 as well as this and my old power supply does not have a pcie connector
https://linustechtips.com/topic/915088-please-help/#findComment-11227978
that's my pc https://www.amazon.ca/CYBERPOWERPC-GUA882-Desktop-FX-4300-7200RPM/dp/B01IPY2XC0/ref=sr_1_5?ie=UTF8&qid=1523396316&sr=8-5&keywords=cyberpowerpc
https://linustechtips.com/topic/915088-please-help/#findComment-11227980
Just now, tylerharding69 said:
should i upgrade my processor, what is one you would suggest that is good but cheep because i just bought the power supply and gtx for 600
hmm... unfortunately you're locked to AM3+ at maximum... Maybe an FX 8300? (used, of course, because cheap.)
https://linustechtips.com/topic/915088-please-help/#findComment-11228049
