Just now, Kamjam21xx said:
I saw it write and finish, so i waited a minute after and exited. Then hit the power button, ive been waiting for like 10 minutes i think.
Im patient from rendering in c4d, i can wait lol. Will update in 10 or 20
You  3d Render? SO DO I lol, although I use blender.
Anyway,  It should prompt you to restart once it gathers all the files. It did right?
https://linustechtips.com/topic/914427-bios-flash-help/#findComment-11221489
1 minute ago, Kamjam21xx said:
My girlfriend uses blender, i use a few other softwares. Upgrading to the 1950x threadripper and wx9100 for prorender in a month.
No but i got 3 screens hooked up if that makes a difference. No signal to the screens.
Did you try a different port? maybe the one on your motherboard?
https://linustechtips.com/topic/914427-bios-flash-help/#findComment-11221497
Welp, she lives. The old rig can still churn out some work for a while.
Thanks for the guidance! (:
Your welcome, now if you've overclocked, your going  to have to do it again since pressing F2 restores all values. This step is necessary for flashing.
https://linustechtips.com/topic/914427-bios-flash-help/#findComment-11221517
21 minutes ago, JustAStrangeGeek said:
"IDE PRIMARY SLAVE: ATAPI DVD ADH2A4H QP53"
Lol. Ive never seen a BIOS call optical media a slave..
its called slave and master in ide, boot 1 should be master , others should be slave
https://linustechtips.com/topic/914427-bios-flash-help/#findComment-11221562
