Hello everyone.
So the other day I ordered a Corsair H60 Liquid Cooler for my CPU, as I was in dire need of a new one.
The the reason I am posting this is for two reasons, one being because I’ve never had a Liquid Cooler before and two because I’m having difficulties installing it.
This is where I’m having difficulties, the fan attached to the radiator has a connector that is 4 Pins, and the Pump that connects to the CPU itself has a connector that is 3 Pins, as well as the SATA Power Cable. However my motherboard has two ports, one labeled SYSFAN1 and the other CPUFAN. However both are 4 Pins? So what do I do?
I’ve already posted about this on TomsHardware, but I have yet to receive anything that is of at all use.
Also, I have a 760GMA-P34 (FX) paired with an AMD FX-6300.
Thanks!
https://linustechtips.com/topic/914362-help-installing-a-new-liquid-cooled-cpu/
You can plug in a 3 pin fan into a 4 pin header or vise versa with no problem. The only issue is, if you plug in a 4 pin fan into a 3 pin header, you get no PWM fan control.
According to the manual, plug the 3 pin pump connector to the 4 pin CPU header, and the radiator fan to the SYSFAN header.
https://www.manualslib.com/manual/405982/Corsair-Hydro-H60.html?page=2#manual
AMD Ryzen 5 3600 | Corsair H100i Pro | ASRock X570 Phantom Gaming 4 | Corsair Vengeance 32GB 2x16gb @ 3200mhz  | Vega 64 @ Stock | Fractal Design Define R4 | Corsair RM750
ThinkPad T480 | Intel Core i7 8650u | Nvidia MX150 | 32GB DDR4 @ 2400mhz | Samsung 840 Pro 1tb
