Hi, I wanted to build a pc that includes rgb lighting and was wondering if this pc would be good for it. I chose the dark case so that the rgb lights would pop against it. Would it work with the gigabyte motherboard as well as all the included stuff?
https://pcpartpicker.com/list/ZxRZRJ
If there is something that would make it better for about 20-50$ more, I will consider putting it into the build as well.
Thanks!
https://linustechtips.com/topic/914158-will-these-components-work-together/
It will all work fine together and is a pretty solid build. Just know that you could get much better hardware if you decide against RGB. But I understand if thats what you want to do then go ahead.
Unsure what power supply to pick?
Check out my HTPC build.
Quote me/others so we can help you
Comic sans is the best font
i was thinking of waiting for the new Nvidia q3 gpus to drop. Would you recommend waiting and trying to snag one of those or a 1060/1070/1080 that people are selling because they upgraded to new gpus?
buy old gpus because they are cheaper, but most likely run hard for mining purposes.
Thanks!
DUDE ...BUILD SOMETHING LIKE THIS...ND SAVE UR $400
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor  ($237.69 @ OutletPC)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  ($34.89 @ OutletPC)
Motherboard: ASRock - Z370 Extreme4 ATX LGA1151 Motherboard  ($149.53 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($165.99 @ Newegg)
Storage: SanDisk - SSD PLUS 240GB 2.5" Solid State Drive  ($69.89 @ OutletPC)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.79 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1060 6GB 6GB WINDFORCE OC 6G Video Card  ($328.99 @ SuperBiiz)
Case: Phanteks - Eclipse P300 Tempered Glass ATX Mid Tower Case  ($47.49 @ Newegg)
Power Supply: SeaSonic - FOCUS Plus Gold 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($83.99 @ SuperBiiz)
Total: $1178.25
Generated by PCPartPicker 2018-04-08 07:53 EDT-0400
Thanks!
Total: $1178.25
OR ELSE ...USE THOSE $400 ND GET SOMETHING LIKE THIS...8600K + GTX1080
Video Card: Gigabyte - GeForce GTX 1080 8GB G1 Gaming Video Card  ($619.99 @ Newegg)
Total: $1469.25
Generated by PCPartPicker 2018-04-08 07:55 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
Total: $1469.25
Still..my build is a bit better
SSD TIER LIST
CPU - Ryzen 7 3700X
14 hours ago, Herman Mcpootis said:
PCPartPicker part list: https://pcpartpicker.com/list/X8QjyX
Price breakdown by merchant: https://pcpartpicker.com/list/X8QjyX/by_merchant/
CPU Cooler: EVGA - CLC 240 74.8 CFM Liquid CPU Cooler  ($89.99 @ Amazon)
Motherboard: Gigabyte - Z370 AORUS Gaming 5 (rev. 1.0) ATX LGA1151 Motherboard  ($184.88 @ OutletPC)
Memory: G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3000 Memory  ($184.99 @ Newegg)
Storage: Intel - 545s 256GB 2.5" Solid State Drive  ($69.99 @ B&H)
Storage: Toshiba - 2TB 3.5" 7200RPM Internal Hard Drive  ($58.99 @ Newegg)
Power Supply: SeaSonic - FOCUS Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($61.99 @ SuperBiiz)
Other: Phanteks Enthoo Pro M SE with 2 x Halos RGB Fan Frames, Integrated RGB lighting, Tempered Glass Side Panel – Black/White interior  ($109.99 @ Newegg)
Other: Phanteks PH-FF120RGBP Halos RGB Fan Frame – High density LEDs, RGB,  ($9.98 @ Amazon)
Other: EVGA GTX 1080 Classified ($599.99)
Total: $1618.46
Generated by PCPartPicker 2018-04-08 22:48 EDT-0400
Did some tweaking to it, is this decent? I was trying to get as much rgb into the build as possible.
get an MX500 or sandisk/WD 3D instead, otherwise it's fine.
