Setting up fans help
Solved by WoodenMarker,
The 3pin header from the cooler is for reporting rpm. If you plug your fans into the splitter on the H150i Pro, you should use Corsair Link software to control the fans where you can choose which temp reading the fans respond to. If you'd prefer to use the motherboard settings, plug your fans into the motherboard fan headers instead of the splitter on the H150i Pro.
l3eyond ·
1
Serendipity1344 ·
Posted in Graphics Cards4 -
1
1
5
1
toxic_worper ·
16
