So I have a 120mb/s of download from videotron (wich is stable) that gives me a real 15mb/s of downlaod on my pc normally
but strangly I have some weird speed drop on some sites/ application / game
LIke on steam(game Provider) I download at 16mb/s but if I try the ookla speed test like any other test I have 1-2 mb/s of download and lower
On Origin, when I try to play a game (Battlefield) it can't connect to servers
But I could download the game at 16mb/s
It always says there is a problem of ping with servers
It doesnt look like a problem that happens sometimes it always do this.
And I tried many things like
Resetting Router
resetting computer
changing cable
Downloading latest ethernet driver
If anyone know anything about this
I would appreciate the help
-Alex
https://linustechtips.com/topic/913794-network-speed-problem/
you have 120Megabits per second, but steam is downloading ay 15 megabytes per second.
Those speeds look correct.
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
https://linustechtips.com/topic/913794-network-speed-problem/#findComment-11215980
This is what works , on internet , while playing games , speed test , the download speed / Upload speed is really bad ,
But when I download the games it goes fast .
This is my problem , it isn't a problem of sometimes, it is always like that !
http://www.speedtest.net/result/7225596180 Like I said really poor when I do the test
But you can see in the screenshot, i download fastly.
(Both speed has been taken the same momment)
https://linustechtips.com/topic/913794-network-speed-problem/#findComment-11238752
