I've decided I'm gonna have to bite the bullet on an external hard drive for my PS4 and was wondering if anyone knows of any that definitely work and are good value and not the branded game drives from Seagate. I think a 1TB should be enough but if it's not a lot more I might just go for the 2TB. Any suggestions?
|| CPU: AMD Ryzen 5 1600 (@3.9GHz) || Motherboard: ASUS Prime B350 Plus || Cooler: Arctic Freezer 33 eSports Edition || GPU: EVGA GTX 1070 SC || Memory: 16GB G.Skill Trident Z RGB C16 (@2933MHz) || SSD: SanDisk 128GB || HDD: WD Blue 2TB, Toshiba 2TB, Transcend 1TB || PSU: Corsair RM550x || Case: Fractal Design Focus G || Monitor: 2x AOC 23” I2369VM IPS Full HD, Samsung 32" LED TV Monitor || Mouse: Logitech G703 Wireless || Keyboard: Cooler Master MK750 RGB (Cherry MX Brown) || Speakers: Dell Stereo Speakers || Headphones: Sennheiser HD 4.40 BT / Samsung Galaxy Buds ||
https://linustechtips.com/topic/913733-external-hard-drive-for-ps4/
Just about any decent USB 3 hard drive will do, but make sure it doesn’t have a built in USB hub. I made the mistake of buying a drive with two extra USB ports on the front, and the PS4 sees it, but refuses to use it. This does also mean you’ll be permanently tying up one of the USB ports on the console...
The Seagate Backup Plus Slim (https://www.amazon.com/dp/B00FRHTSK4) is a solid external drive. Alternatively, you can always pick up an external hard drive enclosure and use any 2.5-inch (https://www.amazon.com/dp/B00OJ3UJ2S) or 3.5-inch (https://www.amazon.com/dp/B01MZC303G) SATA drive of your choice.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
I know but I only have 1 controller that I normally just charge when it needs it. It'll look a little messy but it's not exactly a show piece and I can't be bothered migrating my whole PS4 OS to a new drive.
Thanks for the recommendation but for some reason it costs £100 here in the UK so I'll have a look elsewhere
Any external drive as big as 8TB should do, just watch out and make sure it has no additional ports, just the one USB and power. I use a 1TB mobile USB3 drive and it works just fine.
Cool thanks
  • 2 weeks later...
You can choose from the list here: https://10best.tech/best-external-hard-drives/
They've listed the speeds and warranty information of particular external hard drive depending on the needs of customer. I'm sure you'll find a Good one for your PS4
If that doesn't work, you may be able to find the 2TB Seagate Expansion for a bit less. Should be able to find one of those two in your budget on the UK versions of some of the larger online retail sites.
Seagate Technology | Official Forums Team
IronWolf Drives for NAS Applications - SkyHawk Drives for Surveillance Applications - BarraCuda Drives for PC & Gaming
