Hey guys my motherboard is MS 7613 ver1.1 with i3 530@ 2.93 GHz ..today I got an i5 750 and so I removed the cooler and i3 and inserted the new i5 with new thermal paste.. and connected everything ...but when I power on the pc there is no display ...then I reinserted  the i3 and it worked fine....
So what is the problem here???
Why don't I have display with the i5 ??
I tried restoring CMOS but nothing changed...plz help
https://linustechtips.com/topic/913564-no-display-after-changing-processor/
Dead CPU maybe? Your motherboard might need a BIOS update, or it just doesn't support the i5.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
i3 530 has Intel inbuilt graphics. The i5 750 does not. You will need a discrete GPU to be able to run the display with the i5 750 CPU.
Are there any beeps when starting up? (Nvm assumed you were using a discrete GPU anyways)
My bad again, just saw another post where you said you had a discrete GPU, make sure you have your monitor plugged into that and not the motherboard (Even if you are using a CPU with built-in graphics)
PC Specs:
CPU: Intel Core i7-8700k @ 4.7GHz Turbo
Motherboard: Maximus X Hero (Wi-Fi AC) LGA1551 (300 Series)
RAM: 2x8GB Trident Z RGB DDR4-3200MHz
GPU: Gigabyte G1 Gaming GTX 1080
SDD: Samsung 850 EVO 500GB
HDD:  Seagate Barracuda 2TB
PSU: Corsair RM650x
Cooling: Corsair H115i Pro RGB
OS: Windows 10 Pro (Un-Activated Currently)
Main Display: Dell S2417DG 1440p 144/165Hz G-Sync (2560x1440)
Secondary Displays: 2 x Dell P2312H 1080p 60Hz (1920x1080)
Keyboard: Corsair K95 RGB Platinum
Mouse: Logitech G703 Lightspeed Wireless Gaming Mouse
Headset: Massdrop x Sennheiser PC37X Headset
I used a gtx 760 for the pc and also no display all connections are correct and every fans spin and turns on...even the CPU gets hot but no display at all
Plz help me with this problem .....I spent 30$ or less (1500 INR) for the CPU .... Is it dead ??? But it heats up even I don't have display
